68, 69 headliners different?
Started by jaak, May 03, 2011, 09:19:57 PM
jaak
I started installing my headliner on my 69. I got a new headliner, still in the box from PUI, and on the box it says '68 Charger. Now my question is the factory headliner I pulled out of the 69 was a one piece, the top and the sail areas. And you had the little short bows for the sail areas. Now this '68 liner is different, It has a roof section, but no sail areas attached, but comes with two triangular shape pieced (I assume to cover the cardboard pieces that clip to the sail panels). Make sense? Whats the deal?
Jason
resq302
To my knowledge, headliners are the same 68-70 for the chargers.
Brian
DJReynolds
68-70 are the same headliner, most of the re-po headliners are done that way.
DJ Reynolds
Auto Upholstery (retired)
no40jm
I would say it's the wrong headliner. You should have a one piece headliner with cardboard under the headliner in the sail area. (headliner  goes over the cardboard) Legendary sells the correct headliner!!!!!!
"If you chop your own fire wood it will warm you twice."
"The man who thinks he can and the man who thinks he can't are both right." HF
resq302
Quote from: no40jm on May 10, 2011, 12:08:27 PM
You mean the headliner covers the cardboard but does not get glued to it.  Just so there is no confusion.  Originals were pulled tight in front of it and never glued down to the cardboard.
Brian
jaak
Yep box listed as a 68, but it was a '3' piece headliner (sails seperate), the one I pulled out was a one piece. I got it in though, looks pretty good, I'll post pics later.
Jason
no40jm
Quote from: resq302 on May 10, 2011, 02:42:09 PM
I think the headliner was glued to the sides of the sail cardboard.
DJReynolds
Quote from: no40jm on May 11, 2011, 06:49:34 AM
This is the correct way for gluing the sail panel tails to the board.I have installed many of these headliners in the past, and every one that I did was like that.
DJ Reynolds
