rally or regular dash
Started by 67tbird, April 11, 2011, 08:42:40 AM
67tbird
pic of dash--I need bulbs.any ideas on how to get this melted saran wrap off seat?
ralley72
Rallye dash. no idea on the plastic on seat.
Mike
1973 Roadrunner 400 mag. 4 sp
its the "standart" rallye cluster.
this is actually the standart cluster
even there is one EVEN MORE BASIC, silver instead woodgrained:
there are two more cluster options on Rallye line, one with clock and the other with tach... both are the same but just a gauge change, however not the same cluster than your one ( note the two small openings with diff gauge setup ):
( this one is specifically a 74, with icons labels at side of switches but thats a diff on the bezel only. 73/74 got also diff design AC control )
71 cluster are the same but with 150 speedos, although you can find laters with 150 speedos too
this is for example, one like your one, the basic Rallye cluster, but 150 speedo:
all 71s were with this 150 speedo, and actually I think mostly 72s and some 73s, maybe "performance" models ?
here is one with 150 speedo and clock
and here is one with tach in place of the clock
lisiecki1
i have a 150 speedo that i took out of my ralley cluster, if anyone knows someone looking for one....
67tbird
Hey Nacho, those pictures really helped! I be ordering the rallye bulb kit, the only bulb currently working is the high beam indicator. The seat belts that came with the car aren't retractable and there aren't any wires, so I probably need to go junk yarding for them, what years will work with my 72? I can see a bracket through headliner where a shoulder harness would attach, but no rear clip to stow it, or is it permanently attached to lap belt? Thanks all for your help, Dave
72 and 73s are the same on wiring inside the cab and seatbelts... everything is the same
shoulder fronts are mnot retractable, they are manually adjustable and attached to roof. ( 71 too, BUT won't match 72/73 assembly )
Engine bay harnesses changes on engine harness ( as far is electronic ignition ) and headlight harness on couple of wires, easy to match anyway if required ( washer, brake warning, horns and something else I can't recall right now )
The 72/73 seatbelt assembly looks like this once everything is hooked up:
below, is how it looks clipped to roof
