Forged 383 damper
Started by Nacho-RT74, April 06, 2011, 11:49:08 AM
what casted number on Damper do I have to get for 383 forged crank ? I have known 440s and 383s are diff
heyoldguy
2658457 was used on all forged crank 383s and 440s from 1958-1971.
3614371 was used on standard performance, forged crank, internally balanced 440s in 1972 & 1973 and should work on a forged 383 crank.
so is not true about 383 and 440s being diff damper ?
( the PN change must be for the non offset hole to pulley on lates then )
heyoldguy
really great info there... some of it I already had it, but not everything.
but now I have doubts about 3614371 and 3614372. what it could be the diff ?
It looks 3614371 looks to be ideal being I'm trying to fit a cast 383 and non offset pulley, but still what could be the dif with 3614372 ?
YOU KNOW... I'M STUPID!!!! this info is on the Direct Connection Book ( book what I have ) :brickwall:
still will be nice to know the diff between 3614371 and 2
heyoldguy
The difference is the rods used in the engine.
The 72-73 standard performance 440 used the LY rod and the 3614371 damper.
The 72-73 440HP engines used what are know as 6-pack (or HP) rods and those engines, even though they had forged cranks, used a special damper (3614372) like the 6-pack and 71 440HP engines (damper 3512017).
:2thumbs: Thanks. Sounds logical!
I guess these numbers are CASTED and not SERVICE numbers ?
