ENGINE WIRING DIAGRAMS NEEDED plz
Started by Rayman2, January 05, 2006, 03:16:10 AM
Rayman2
hey hows it going everyone long time no see well this is my perdicament ... i have a 1972 dodge charger se it has a 440 in it and i had to replace the wiring harness in it i didnt buy a stock replacment one stupidly so yeah i bought a 12 curicut painless race/strip harness for it well i have most the engine done except i dont know how to wire in my balast resistor or my voltage regulator ! plz help with some engine wiring diagrams ... thanks guys this project is so close to being done i can taste it i just keep fryin points and coils though cause those two things arnt hooked up ... thanks for any help ^^
41husk
I have a 68 tech manual that should have the wiring diagram in it but it will be a little different than the 3rd gen,  I am sure some one can help you out but you may try posting the tech section.  There are many paople on here who can help you out.  Good luck!
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
Here is some wiring I have made and they show the most important parts of engine harness. Bulkhead cavities could it be some tunred around. Colors are the closers to the originals.
Ignition and charging are show separatelly, but oh well you can make the mising up of both to make the wiring. Would rest just the Violet wire of water temp sender unit, Tach if is equiped what is hooked up to negative terminall of coil, Oil sender wire and... don't remember what else is on that harness.
Also it appears separatelkly the blue wire what is the main source of all the wiring, what includes the electric chooke control feed.
BigBlackDodge
I have the 71 elec diagrams scanned from the shop manual. PM me if you want them emailed.
BBD
differences with 71 diagram is the electronic ignition system, that's why I posted this diagrams that I made long time ago. I also have it :P
Rayman2
wow thanks alot guys you all are to kind appreciate the help the diagrams worked beautifullly i understand them ^^ and now i can go wire my car tomorrow or somthing ^^ sweet !
