360 Harmonic Balancer
Started by nrt69, March 24, 2011, 08:37:30 PM
nrt69
can I use the old harmonic balancer off the 360 im building, or should I buy a new one?
If a new one, does anyone know of a reasonably priced replacement?
tricky lugnuts
As to whether you can reuse it or not, they can degrade over time, so close visual inspection is warranted. You want to make sure it hasn't "slipped," i.e. that it still gives accurate display of timing marks.
Looks like Summit sells an OEM style non-SFI balancer for about about $80 - should be OK for a stock rebuild - and they go from there up to $400 plus, depending on how radical of an engine you're building and how radical of a balancer you want.
Of course, I ordered a new low-dollar balancer like that for my 440 build (not from Summit) and the machinist bolted it on and found the indicator off by about 5 degrees - so be careful with any new parts you order. After that, I reused my original like you're considering, albeit with a repair sleeve.
Also, 360 engine is external balance, so if you do get a new one make sure you get the right kind.
You might consider purchasing a rebuilt or having yours rebuilt.
http://www.damperdudes.net//index.php?cPath=26&osCsid=3dc943923b9c79e3d3e3565672ab47fd
