Wire from O'reilly
Started by HANDM, March 19, 2011, 06:50:08 PM
HANDM
I did an ammeter bypass on the charger last spring but didn't make the hard connections and left the wire ends dangling, upon stripping the "new" wire, I found that six plus inches of the wire was RUSTED badly!
I had cut the big black wire on the original 42 year old harness at the same time I did the bypass, upon stripping, the old wire was in perfect condition with no signs of corrosion
I strongly suggest that anyone doing or has done wiring in their car, do a quick snip and see what I suspect could be a huge problem down the road
I plan on ripping out the wire and getting some stuff that is made here in the USA
daveco
This is the second time I have heard of copper "flashed" steel wire from china (steel wire with a very thin copper plating).
http://bbs.homeshopmachinist.net/showthread.php?t=40772&highlight=copper+wire
Gotta start checking new wire with a magnet I guess.
I've also seen what appeared to be nice heavy gauge copper jumper cables that were actually copper flashed aluminum.
R/Tree
HANDM
Very Sad to have to check country of origin on wire now  :rotz:
