Air Grabber Vacuum hoses?
Started by 71butterbee, January 03, 2006, 04:48:07 PM
71butterbee
I have a set of Air Grabber/ Ram Charger hood vacuum hoses but im unsure if it is complete. I believe this set of hoses came off a 70 Road Runner. I know it's complete from the fire wall to the switch but im not sure about from the fire wall to the actuator. Are the hoses that continue along the underside of the hood part of the hoses at the firewall? The hoses at the fire wall on mine are about 10" to 12" long leading me to believe the hoses that run under the hood to the actuator are ether a separate set of hoses with a connector tying them in with the hoses through the firewall or the hoses that I have are cut. Can someone answer this?
Nupe
BTT
Not sure since my repo hoses came in one piece and I assume need to be but to fit.   Hood isn't finished yet (and at this rate probably never   :rotz:) so I haven't figured out the lengths yet...
:icon_smile_cool:
'79 Lil'Red Express.
daburnout
www.roadrunnernest.com   has  the   diagram  info  .  Also  lightnigjar.com/cars   has   all  the  part  #    has   good   refernce  for    carbs  ,   distributor  ,      etc    check  it  out ,   I  also     working   on  a   grabber  hood   no  rush  to   get  it   done   it   was   bought    before  the   price  went   through  the  roof
