cam install question
Started by 1968_Charger, February 21, 2011, 10:18:04 PM
1968_Charger
I'm looking into swapping out my cam. i have a feeling that my current cam may be degreed wrong or its just too big, I'm also concerned that the timing chain may be stretched. my question is, in the walkthoughs that i've read it says to make sure the dots on the timing gears line up at tdc before removal. what if they dont line up correctly? do i just make sure my crank gear is straight up and when i put the cam gear back in make sure it lines up then? never done a cam install before so any help would be appreciated.
Cooter
Most of the time if the cam WAS degreed, the crank gear will have THRE (3) possible keyways and will be lined up with either "Dot to dot" which is TDC, or "Straight up"..Otherwise, it will be "Retard X amount of degrees, or Advanced X amount, usually around 2-3 degrees.
If you pull it down and find that the "dots" don't line up, STOP, TAKE A PIC, and let us see where they actually ARE..Then, we can tell you whats what...
1968_Charger
ok, sounds good. i wont be doing this until probably april or so. just wanted to get some answers before i start ordering stuff.
