spark plug wire boots???????
Started by 69chargerdad, January 03, 2006, 09:39:19 AM
69chargerdad
     any one know what boots to use on a 69  charger  440    with tti headers?????      Ken
471_Magnum
What heads?
Generally, I found 135 degree boots work best in most applications, including E'brock heads and TTi headers, as well as stock heads and Hi-Po manifolds. They give you a lot of flexibility to direct the wire away from the header or manifold.
Both Taylor and Moroso have 8mm wires with 135 degree boots.
Straight boots would be my second choice.
69chargerdad
thanks we were actually looking at the taylor 8mm wires with the 90/135 boots        Ken
The straight or 135* boots will work fine with e-heads and tti headers. I'll be using the MSD 8.5 mm flexible boots on mine. There's all kinds of boot clearance with the tti's and an angled plug head.
I generally use the MSD straight boots these are bendable so you can adjust the angle
BigBlockSam
i also used the MSD straight boots . they worked well. Rene
RallyeMike
The 135's work great with headers for clearance and something to grip when pulling them off.
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
