Vinyl top..can you change the color?
Started by Grizzly, January 02, 2006, 06:58:23 PM
Grizzly
Just out of curiousity, can you paint successfully or change the color of the vinyl tops without damaging them? I am not talking about replacement, just changing, from the original white color to black?
Mopar440+6
To change the vinyl top color from white to black your best bet is to get a new one and replace the white one. Any typical vinyl dye will not hold up to the weather.
"If you cant fix it with a wrench, get a hammer. If that doesn't work, get a bigger hammer!"
General Ryan
How did the dealers dye them when new for stuff like "White Hat specials"
Or was it just conventional and wore of off after being in the weather for awhile??
Quote from: Mopar440+6 on January 02, 2006, 07:20:20 PM
I agree, the best way to change colors is to just put on a new top. They aren't expensive and labor isn't bad either.
Quote from: General Ryan on January 02, 2006, 08:03:12 PM
A "White Hat Special" wasn't always a white top (but it was always vinyl). The color of vinyl top was coded on the fender tag so that was handled at the factory.
:iagree:
Check here & scroll down to the A41 White Hat Special option to see what it came with....
http://richmondcountymopars.tripod.com/1969chargerregistry/id19.html
Smoke20
My car was F8 with the A41 package.  Inside has white seats, door panels and headliner with black dash and rug. White vinyl top outside.
I still can't decide if I should paint her factory and do the white top, or go totaly different, like Plum Crazy.
Kevin
It's MoPar or No Car!  :drive:
'69 Dodge Charger - Black primer
01 Dodge Intrepid R/T 3.5L Magnum V6 36K
05 Dodge Grand Caravan SXT Inferno Red, Loaded
Grizzly
Well there isnt anything wrong with the one I was thinking of, other than it being white.... :D so I guess it will stay that way... :)
Quote from: Smoke20 on January 03, 2006, 01:58:26 PM
I think that would be a great combo!
Plum crazy on a 69 just doesnt do it for me personally.
Smoke20
I dunno....
Anybody have a pic of a white hat F8 car.....
Kevin
Smoke20
Kevin
To be honest... paint doesn't worth againts install a new top... Maybe you will spend a little bit more and will have a little bit more effort, but worths the effort
