fuse box amps
Started by fireguyfire, January 02, 2011, 08:53:45 PM
fireguyfire
Hi guys; I am finishing restoring the dash wiring harness, and have just finished redoing the fuse box. My problem is that although I can read what each slot is for, I cannot read all of the "amp" amounts printed on the fuse box for each one. I have referenced my factory shop manual, and it said to reference the amps listed on the fuse block! Around and around we go!!!
The ones I need help with are, as follows;
1)  ACC    PRAC
2)  C/LTR   DOME LP
3)  TAIL     SIGNAL? (Can't quite read)
4)  INST.     LPS
The other 2 I can read; any help would be great, then I can put the restored harness to bed.
'66 Coronet 500
'68 Charger
'69 Sweptline Adventurer pickup
'56 Dodge Regent
fireguyfire
'66 Coronet 500
'68 Charger
'56 Dodge Regent
Accessory, taillamps, cigar lighter- 20 amps
Emergency, stop and dome lighting- 20 amps
Heater and AC- 20 amps
Instrument lighting- 3 amps
Radio and back up lights- 7.5 amps
This is from the 69 FSM.
These are the things I never remember to shoot a picture of. Maybe I can sneak over to the garage this evening and find one with the lettering in good shape.
The FSM should be right though.
