68-69 Dash Frames
Started by 69DodgeCharger, July 19, 2005, 05:57:05 PM
69DodgeCharger
The post on the lower pads got me thinking, are the dash frames interchangeable between 68 and 69's? Or, will there be an issue with the ashtray location. Also is there a "factory plug" for the location hole of the rear defrost switch on the 69 dash frames?
http://www.mypowerblock.com/profile/69DodgeCharger
The bugle sounds the charge begins. But on this battlefield no one wins.
PocketThunder
thats a good question.  in fact i have one of each tore apart on my basement floor right now.  when i get home tonight i'll take a look see.....
"Liberalism is a disease that attacks one's ability to understand logic. Extreme manifestations include the willingness to continue down a path of self destruction, based solely on a delusional belief in a failed ideology."
JimShine
The ashtrays are in the same spot. The difference between them is internal. I wonder if the assemblies are interchangeable? BTW, I saw a 1969 Super Bee this past weekend with a '68 style ashtray! The rest of the dash was '69 correct though!
The rear defrost on 1969 was next to the heater controls and is also the switch and placement of the '69 convertable tops. There is no delete plate. The metal is cut for the defroster switch cars and left alone for standard cars.
PocketThunder
Ya i just held them up to each other and they are pretty much the same.....
Check the hole for the ignition switch.
rebby
Quote from: Troy on July 19, 2005, 11:39:26 PM
What is the difference between the 68 and 69 ignition switches? My 69 is a tad sloppy and I'd like to replace it but nobody makes a replacement???
Curt Rebelein, Junior
1969 Charger R/T SE (500 Stroker/833/D60 w/XP VIN)
1969 Charger (440/727/8.75, GL Project)
Quote from: rebby on July 20, 2005, 09:20:38 PM
68 switch is on the left - 69 on the right. No one makes repros but send me a PM and I can help.
purple70rt
They show a 69 one for $99.00, it's the first place I found that has them.lhttp://www.jacksautoparts.com/catalog/electrical.html
Quote from: purple70rt on July 26, 2005, 06:26:10 AM
But do they actually have it in stock and ready to ship? :P
purple70rt
Sorry Troy, I don't need one so I don't know if they are in stock, just thought it may help someone.
Quote from: purple70rt on July 26, 2005, 03:57:58 PM
I was just asking because the last time I was hunting one for somebody else there were places that listed a price but never had them. They are so scarce that most places won't even list them.
rebby
I need one but am not in any hurry which might hurt me in the end since I haven't been looking... $100 seems stiff though. Is there any way to just convert my dash to use a 68 style one?
69DodgeCharger
"I need one but am not in any hurry which might hurt me in the end since I haven't been looking... $100 seems stiff though. Is there any way to just convert my dash to use a 68 style one?"
Rebby,
That's what I was wondering too since I have a perfect dash harness and working ignition switch and set of door locks from a parted 68 charger. Could I just swap in those parts and be good to go? Anybody got an opinion on this?
Look at the picture above. The diameter of the '69 switch (and corresponding lock cylinder) is much larger. To make a '62-'68 switch fit you'll need to create an adapter. I've seen it done in the past but I don't have the information handy. I'd start making them but I haven't seen any demand yet. The '62-'68 switches are ~$15 and I've gotten lock cylinders for $7 so it's a much cheaper route to go if you can get it attached to the dash.
I think the thread has been completely hijacked now.
69DodgeCharger
Thanks for pointing that out Troy... I see what you are saying about the difference now....good thing I have a 68 dash frame also.... :yesnod:
MTPOCKET
Quote from: MTPOCKET on August 12, 2005, 12:08:21 AM
Rebby here is a link for a store on ebay that sells ignition switches.
http://stores.ebay.com/Thomas-Sestak-Collector-Car-Parts_Mopar_W0QQcolZ2QQdirZQ2d1QQftidZ2QQtZkm
They have lock cylinders listed - no switches. Rebby found one already. :D
charge70
I believe that the fuse boxes are in different spots.69 is in the glove box,and 68 is attached to the bottom of the dash frame on the passengers side pointing down in the footwell area.
