Project '68
Started by KSChrgr68, November 27, 2010, 01:19:14 AM
HOTROD
Get your self a good 4' level ,jack stands (4) ,subframe connectors and good luck  :2thumbs: (ebay) or a B body donor car !!
What the Hell-Dumass !
KSChrgr68
removed the gas tank, front grille support and assembly, seatbelts out of the cab *some of em* made a few rough cuts around the trunk pan to loosen it from the frame rails, removed splash guards on the driver side fender area, hood hinges removed, trunk rubber seal scraped off, took the horn off * :lol:* ....  went to wal mart and got a bright LED flashlight for under frame light.  Going to attempt to remove the front bumper assembly and rear axle/leaf springs tomorrow night.. Sort of a sporadic disassembly lol, but i see something easy I can take off, grab a ratchet and go at it..     :yesnod:
I got my dreamcar in 2010
MoparSam
Rough start but a good one. Looking good. :2thumbs: As for the dash coming out, the windshield has got to be out.
'68 Charger R/T 440
'74 D-100 Adventurer 318
'75 Ramcharger 360 4x4 4 Speed
'78 Ramcharger 360 4x4 4 Speed
'67 Dart GT (Soon 440)
'05 Ram 1500 4.7
1/2 '71 Dart
SRT-68
Youre doing well :2thumbs: Keep the photos coming!  :popcrn:
KSChrgr68
''As for the dash coming out, the windshield has got to be out.''
excellent, thanks! :cheers:
KSChrgr68
headliner and dome light are out, mice kinda made two endzones of insulation padding above the driver and passenger doors, lil bastards.. it was all stuffed above the pass and driver bow bars lol...  :eek2:  oughta improve the odor coming from the cab now that all the padding has been removed..  Inspecting the chrome around the windshield, making sure there arent any screws holding it in from inside the cab.. will remove the chrome trim and then get the windshield out tomorrow, then its dash removal time   :yesnod:  spent most of the evening cleaning and reseting my *shop* it got pretty messy, decided to lessen the stress and tidy up before i start again..  3 days of freedom to tackle some much needed stripping duty.. no peeking lol
date night tonight with my new sweetie, she likes what im doing out in the barn with the ole charger,  :coolgleamA:  didnt get to remove the bumper or rear axle yet.. it will happen, o yes
KSChrgr68
got the windshield out, almost had it cleanly removed too... then it happened..........the lower corner driver side cracked just as i was almost out... :icon_smile_dissapprove: :icon_smile_dissapprove: :icon_smile_dissapprove: :icon_smile_dissapprove: :icon_smile_dissapprove: :icon_smile_dissapprove: :icon_smile_dissapprove:  taking a break.... I think the cold was the culprit...
paironines
I've seen worse, looks like a good project. I'd turn the hood on its side if you plan on using it again.
ktneifert09
There's a great book called project charger. Pick it up at amazon. This site has an awesome instrument cluster restore thread. Mine looked like yours and now it's a beauty. Keep on keepin' on. Oh, and keep the sweetie; my wife is a big supporter of my project and it makes all the difference when you have a "I busted the darn windshield" day.
Plans are useless; planning is indispensible.
Especially with an old car!
Patronus
The OEM glass is extremely brittle, it happens.
Besides, you would never put that crap back in... wait till its all shiny, you'll have to replace everything.
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
Vainglory, Esq.
This car seems like a good candidate for the SRT-68 conversion - use a modern SRT Magnum/Charger and put the body on it.
KSChrgr68
Quote from: Vainglory, Esq. on January 02, 2011, 06:36:49 PM
ya thats out of my budget and no where near my desires for a *Classic car*  no way!   :eek2:
drifter69
There is something about a carb on a motor and the smell of fuel.
KSChrgr68
just got that Project Charger book that was mentioned earlier  :icon_smile_big:
if anything itll be good reading while on the commode  :lol:
djcarguy
 :popcrn: dont scrap it and dont spend lots of money on parts till it is all apart and you inspect it all.. and start looking at it again with clear vision and help from others,2 heads ya know..  well ya said nothing bout the engine,sep 383???  pull plugs blow out cylinders and shot oil in ta soak,does it turn??? look in eng and sides of block for cracks between soft plugs or water in oil??    keep on it youll learn alot and have some fun.  that rusty inback may be race frame and tubs and lots of home fab alumminum panel and loads of fun ,than down the line a more stock body ta do up..  well have fun and hangin there :2thumbs:  well if ya puts a jak undar ta fram an it pops up inta the kar ya just may have a little rust - ish spot ta fex   ,lol ..dj
SRT-68
Quote from: KSChrgr68 on January 02, 2011, 10:58:09 PM
The conversion will cost less in the long run because you have to repair frames and floors, rebulid engine and trans, then rebuild or replace brakes,suspension and electrical anyway.
Oh and don't worry about that "classic car feel", you get to keep all of the window and door issues.  :lol:
KSChrgr68
nope im gonna go old school, no new stuff in my charger unless its designed for the old 68..
westcoastdodge
Quote from: drifter69 on January 02, 2011, 11:36:34 PM
:yesnod:
I don't care what is is designed to do,I want to know what it can do.
Gene Kranz
Patronus
Check out this frame this guy's using! Your car could use this!!
http://www.dodgecharger.com/forum/index.php/topic,63123.75.html
'08 CRF 450r
'12.5 450SX FE
KSChrgr68
been sick the last 4 days, getting better  :eek2:  hope to get back outside and continue the stripping of the car..
SRT-68
Quote from: KSChrgr68 on January 05, 2011, 10:00:29 PM
Wear a mask! There are all kinds of things growing in that car that will spoil your day. I know I sound like an old woman when it comes to safety, but I have watched a lot of guys (including myself) get hurt or sick cutting on these cars.
KSChrgr68
KSChrgr68
damn lol, this cold im struggling with is finally going away..  i slept all day!  :flame:
on positive note:  i have officially started a savings account that I am putting aside funds for the car into.   :coolgleamA:  here we go!
project charger book came today  :icon_smile_big:  doesnt show anything about frame rail repair  :brickwall:  lol
Charger440RDN
Quote from: KSChrgr68 on January 08, 2011, 09:07:18 PM
Read this thread from a member here, this car was in about the same shape yours is in now. The frame and floor had to be replaced. Very good restoration reference. THIS car was in really bad shape.
http://www.dodgecharger.com/forum/index.php/topic,59899.0.html
KSChrgr68
good thread!  snowed today!!  not sad about that, taking a bit of a break from all things charger.. want to hit it again with fresh mind and a warmer atmosphere  :icon_smile_cool:  got a new 14.1 megapixel camera to take more detailed shots to post on here.  got it for a steal!   :D
most of bolts taken from car are bagged and labeled, chrome pieces and other parts set aside on benches and tables.  Good call on the hood, need to turn on its side asap..
