FUEL PUMP PUSHROD
Started by Bobs69, November 21, 2010, 02:14:40 PM
Bobs69
What size socket do I need to get the plug out of the block to remove the fuel pump pushrod.
Pretty sure its a 3/8" Allen head socket
Bobs69
3/8 is too big.  Way to big.
5/16 is a little loose.  I was afraid to pull too hard on it.  I know it'll round it out.  Is there something special I'm missing or what.
Thanks in advance guys.
Back N Black
if it rounds out inside, use a spiral type easy out to remove it...then replace it with a new one
chargerbr549
On my 69 440 it took a 5/16 allen head socket to get out the factory pipe plug, I had to buy the socket just for it, over the years yours could have been changed or gotten damaged by using the wrong size allen socket.
Kevin
Bobs69
Years ago when I rebuilt the engine, well freshened it up with new rings and bearings, the block was sent to the machine shop to be dipped (in whatever that stuff is).  I think they widened some oil gallerys and changed the freeze plugs, they probably did pipe plug too?
Bobs69
Well the snap-on dealer didn't think they made a 11/32 allan socket, so I got the 9mm, not even close.  Looks like it's been rounded out.  I've tried welding to it, no luck.  I'm leary of using the easy outs.  I don't want metal fillings getting into the engine.
Any other ideas.
Oh yeah, here in Ontario Canada that one 9mm socket cost almost $28!!!  WOW
Cooter
Don't I know it when it comes to The "Strap-on" Truck, and prices of tools...That Cam bearing tool everybody complains about when they have to pay the machine shop $50.00 to install the cam bearings? Try $300.00 from Snap-On...
they make an easy-out set that fits into a socket that has spiral left hand threads on the end...one of those shoulf fit into the rounded out allen head hole..no drilling required
I never have been able to remove it. Still with factory rod on block. EXTREMELLY STUCK
Cooter
There ain't nuthin' that a torch and a little heat apllied in the right area and amount won't get a loose...Try puttin' a little heat round the plug and see if it'll come loose.
Quote from: Cooter on December 17, 2010, 11:14:07 PM
just be careful, and make sure your fuel pump hose is capped off and tight...gas fumes go boom sometimes
FLG
Quote from: Nacho-RT74 on December 18, 2010, 02:20:42 AM
just sometimes huh!?
Yea, depends on where is from...Venezuelan fuel might just break out into a fiesta, while petrol from England tends to just break out into a game of cricket, American gas though is the type that tends to just explode
Bobs69
Quote from: Cooter on December 17, 2010, 06:24:45 PM
Stap on truck!  haha that a good one.  I'll post some pictures of the ...............actually I won't the spiral left handed thread tools I have do require drilling.
Bobs69
Quote from: A383Wing on December 17, 2010, 08:47:19 PM
Do you have a link to such a tool.  Is this another snap on item?
Quote from: FLG on December 18, 2010, 02:50:32 AM
:smilielol:
well depends, what USA gas, since Citgo is Venezuelan :lol:
Quote from: oldcarnut on December 18, 2010, 03:52:29 PM
Another type we use and I believe A833Wing was refering too.
http://www.csnstores.com/asp/show_detail.asp?sku=OGH1261&refid=TF49-OGH1261
Prices vary all over the place depending where they are.
yup...those are the ones I use at work...
62 Max
Quote from: A383Wing on December 18, 2010, 08:09:53 PM
Those are actually about the only ones that work! :Twocents:
Bobs69
Quote from: 62 Max on December 18, 2010, 08:19:12 PM
What do you do with them?  Tap (hammer) them into the rounded hole?
yup...find one that just fits into rounded out hole, tap in with hammer...left hand threads will bit into part harder as you turn it out.....
oldcarnut
Sorry man, I just reread my quote and saw I reffered to you as a tranny :lol: :slap:
Quote from: oldcarnut on December 18, 2010, 10:42:36 PM
No worries..I missed it also...
and I've been called worse...
  :smilielol:
