Paint gun question
Started by chargd72, November 15, 2010, 01:17:04 PM
chargd72
Doing my very first paint job.  Primer went on smooth but paint and clear are going on a little gritty.  Not getting much orange peel.  Does this mean it's starting to dry before it hits the surface?  Should I go with more/less air?  More/less fluid?  Gun pressure is at 40psi.
Thanks.
Silver R/T
I suggest you log onto http://www.hotrodders.com/forum/body-exterior/ and search that forum. VERY informative site and after reading a bit you should be able to hone your painting skills.
I would suggest this particular thread for the start....
http://www.hotrodders.com/forum/purple-harbor-freight-hvlp-guns-sale-178459.html
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
chargd72
Thanks, some good info on here.  Got a few pointers I can try.   :cheers:
jaak
What size tip does your gun have. Primers usually require a larger tip size, I have a 1.8 for using with urethane and epoxy primers, and if using polyester primer, you need an even larger tip (I have a 2.0 for poly, but still have to thin it about 10% to get it to spray to my liking).
****Edit**** I read your original post wrong....I thought you said your primer was 'gritty'.
Jason
