Not Starting
Started by CornDogsCharger, October 24, 2010, 12:38:44 PM
CornDogsCharger
My '66 Charger has been cranking up fine until last week.  Earlier this year I replaced the dash harness as well as the engine/forward harness.  The car sat for about 2 weeks without been cranked.  I cranked it up and been cold-natured like it is, it ran for a few seconds and then died (not out of the ordinary).  I went to crank it again..... nothing.  Since I always disconnect the battery while it is parked I made sure the cables were tight.  Still nothing.  I figured something was wrong with the starter relay, so I replaced it with a new Standard relay.  Went to crank it... nothing.  So now I'm thinking something is wrong with the ignition switch.  I decided to bypass the Ign switch and jump the BAT and SOL on the relay with a screwdriver.... still... NOTHING.  So what does it sound like??  Starter solenoid?  Please help!
Justin
1966 Dodge Charger
1969 Dodge Charger (DMCL Project)
1969 Dodge Charger (WB General Lee "GL#004")
1969 Dodge Super Bee
the reason why engine shutted off has nothing to do with starter motor. However will fix first the cranking deal.
check starter wires underneath the car, and jump directly there. If not crank, will need to check starter motor. I'm toward to motor solenoid fail
Then, for a while you are working on that, check if you get trigger signal at yellow wire arriving to starter relay when trying to crank from ign switch
check for voltage at ballast with ign switch in RUN
Paul G
If what Nacho says doesnt fix it, and you are getting power to the starter solenoid, try smacking that starter with a hammer while someone is holding the key to start. May just have a stuck bendix.
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
:iagree:
or worn bushings making the armature meet the fields
