Engine won't turn over
Started by ktneifert09, October 16, 2010, 11:02:45 AM
ktneifert09
I took the engine apart down to pistons out to see what I had. Looked good so I put it back together all torqued up right. Oiled the crank lightly before I put the rod ends back on. Now the starter won't turn the engine over. Any ideas before I crawl under the car, pull the pan and loosen up the rod end bolts enough to turn it over? :brickwall:
Plans are useless; planning is indispensible.
Especially with an old car!
RD
can you crank it over manually with a breaker bar and 1 1/4" socket?    it may just be that your battery is weak.  get it tested and charged.
ITSA426
Weak starter or bad connections or poor ground.  I'd go a long way not to take it apart if I was sure the assembly was right.
ktneifert09
Got my 1/2 breaker bar and put a 3 foot piece of pipe on the end. Took out the plugs even though they were only in finger tight.  Now I have a really tight crank bolt and an engine that still won't turn over.  BTW - battery is brand new - starter is unknown quality but I'm thinking if I can't turn it over by hand with a breaker bar, something is wrong inside.
Belgium R/T -68
Don't know what kind of engine you have but if it doesn't turn after assembly it's propably
a valve hitting the piston or a wrongly turned rodcap.
Per
RD
Tilar
Quote from: RD on October 16, 2010, 04:36:32 PM
Quote from: Belgium R/T -68 on October 16, 2010, 03:11:44 PM
Per
bingo!!!!
That or if you have a rod cap on the wrong rod, or even the main caps in the wrong spot will cause this too.
Dave
ktneifert09
Thanks guys. Looks like I'll be opening her up. The rod end thing sounds right. I remember something goofy with the last set in. I'll bet I accidentally flipped it. Bummer
terrible one
Quote from: ktneifert09 on October 17, 2010, 02:42:04 PM
Remember to turn the engine over by hand after installing each rod/piston so that if one makes it seize you know which one it is.
Tilar
Quote from: terrible one on October 17, 2010, 02:45:02 PM
  :iagree:
Dave
ktneifert09
I am so stupid. I remember turning it over by hand for all but the last two on the rear of the engine. Oh well, it'll be easy to find. Thanks guys.
