Choke block off
Started by FLG, October 09, 2010, 01:38:54 PM
FLG
Anyone know where I can find a blockoff plate that goes on the top of the intake manifold? Preferbly in billet aluminum.
FLG
Long Island RT
Hey Frank - Why don't you just make one?
I did - 1/4" thick piece of aluminum.  Cut out in seconds with a hacksaw.  File/Sand smooth.  Drill holes for mounting screws.  Polish if desired.  :2thumbs:
I have a piece of aluminum you could have - shoot me your address and I'll ship it to ya!
1969 Dodge Charger RT Restomod<br />Triple Black, 512 stroker, Tremec TKO600 5-speed<br />2005 Dodge Magnum RT - Brilliant Black - Lowered
FLG
Ill be in li this weekend, you gonna be around?
:2thumbs:
Long Island RT
Yup - I'll be around Saturday and Sunday Afternoon.
Shoot me a text when you'll be close to be sure I'm home.
Later.
FLG
Thanks Paul!
I had some time today so i cut  out that piece of aluminum you gave me, i think it looks good just need a gasket and need to sand some parts a little smoother. I counter sunk the screws, i may go with allen drive screws but i like it as is.
Opinions?
Al
1968 Dodge Charger, 383, UU1
FLG
Long Island RT
Looks Great!
Nicer than mine - You'll have to make me one now  ;)
FLG
Quote from: Long Island RT on October 17, 2010, 10:43:09 PM
Looks Great!
Is yours the same shape as a stock one?
Ill make another for ya  :2thumbs:
d72hemi
it look niceer than the one I made 10 years ago, and painted to match the engine. Did you put the gasket under it? I had to pull mine after remembering
Long Island RT
Quote from: FLG on October 18, 2010, 12:09:03 AM
Looks Great!
Now that I'm looking at it closer - I don't think its the same shape.  I have the Indy Dual Plane intake - I think the side by the carb is flat.
I'll have to check it out.
Quote from: FLG on October 16, 2010, 09:57:08 PM
Thanks Paul!
Opinions?
That looks great, nice work Frank  :2thumbs: No need to install a gasket under it when using the Felpro #1215 intake gasket because it blocks off the heat crossover. The cover at that point is purely cosmetic.  ;)
Get a 1/2in 4 hole phenolic spacer to help with conductive heat to the carb. It will also give you some extra room for the carb linkage which can be a problem with stock manifolds and Holley style carburators. Don't forget about the 20-7 holley throttle adapter....you need it with the PF/Holley carb to maintain proper throttle cable actuation.
FLG
Very true Ron..duh! Thanks.
I have the adapter on my current holley so ill just move it over when the time comes  :2thumbs:
FLG
Quote from: Long Island RT on October 18, 2010, 09:31:06 AM
Looks Great!
Is the one you have on there the right shape? When the cars packed away for the winter just give me that one and ill use it as a template.
