Turn signal switches
Started by Ghoste, September 21, 2010, 03:29:45 PM
Is there a difference between the 67-69 switches and the 70-76 ones?
think it might be something to do with the turn signal/ flasher wiring part, as 70 model year switch for flashers changed or at least for a B-body :popcrn: :popcrn:  :scratchchin: :popcrn:
totally diff just right for that reason... all Mopars the same diff.
beside that since 70 you can't turn on brake lights when hazzards are turned on, earlier allows you turn on brakes while hazzards are on.
ODZKing
1970 the flasher as mentioned was in the column.
BTW, these are now available from Chrysler along with a BUNCH of other stuff.  I havetheir restoration catalog here.
70-76 A, B & E bodies
04293102
not 70/71, yes 72 and lates
on second half 71 it was Changed to lates kind with bigger hazzard knob and doesn't fit on earliers column ( diff hazzard knob and provision on column, also diff key courtesy light )
also in  70/71 years some cars got the hazzard ON position pulling out the knob, and some others pushing in
