Mechanical fan
Started by dd44068, September 13, 2010, 10:14:20 AM
dd44068
Ok so I am going to replacce my old 5 blade fan with a 7 blade fan are there any recommendations? i was at the summit website and saw that they're are 3 different types of material, is there a choice that i should stayaway from? When I put all the info in the navigation section it tells me to use a Flex-a - lite 5718, this also allows me to use a clutch. What do you guys think of this?
Thanks in advance for the help,
Dom
Provided the clutch will fit your application I like the MP 5 blade one.  But the model you are looking at doesn't appear to be a bad one.
The ones to stay away from are those cheapie speed shop ones that used to be under the hood of most Camaros or Mustangs.  The ones with the blades barely riveted to the hub.
