Are all 8.75 rearend positive traction
Started by joww3, December 22, 2005, 07:25:00 PM
joww3
Hi, are all 8 3/4 rearend positive traction? Positive traction means both wheel have traction to move the car, right? and when the car is the a jack stand, what direction does the wheels turn when in neutral? thanks for the help.
Joe
471_Magnum
In order:
No.
Sorta.
Same direction w/ Sure-Grip. Opposite w/o Sure-Grip.
andy74
joww3,posi is a general motors term!
that being said,sure grip(mopar)will drive both wheels in a strait line,but there is a clutch pack that disengages for when you are cornering,or if one wheel became stuck.471 answered your other questions,i just thought you may want a better understanding of how it works! :icon_smile_cool:
joww3
 :sick: no more posit....tract...., all Sure Grip from now on. Mine is a 71 383 magnam, and it doesn't have a sure grip, it is a 8 3/4, and when on jack stand, wheel turns opposite direction. anyway to convert mine to a sure grip? do I have to buy a new comlete rearend? and thanks for clearing things up for me.
andy74
you can buy the sure grip,they arent cheap but they are out there!try mancin racing,or randys ring and pinion,or try looking at swap meets,e bay etc.
Rolling_Thunder
there are two types of sure grips used by the factory....    "cone" and "clutch"   if you buy a used one - DO NOT but cone style
andy74
Quote from: Rolling_Thunder on December 23, 2005, 01:27:06 PM
i forgot that part
AKcharger
Just weld the spider gears for an inexpensive sure grip...Yeeeeee Hawwww!
471_Magnum
Quote from: AKcharger on December 26, 2005, 05:11:46 PM
More like an inexpensive spool. Careful around the corners in the wet.
I agree with Rolling Thunder regarding used cones. Only way I'd mess with a cone would be if I pulled it out of a running car after testing it.
Unfortunately, installing a Sure-Grip isn't a project for a novice. So unless you know someone who can assemble one, you've either got to gamble on a used third member, or buck up and have one professionally built.
Rolling_Thunder
I wouldnt run a spool on the street...   even on the dry streets...    doesnt seem safe or logical to me...   plus wears your tired ALOT
471_Magnum
Quote from: Rolling_Thunder on December 27, 2005, 05:19:27 PM
I wouldnt run a spool on the street... even on the dry streets... doesnt seem safe or logical to me... plus wears your tires ALOT
I agree. My comment was intended to be "tongue in cheek". Welding the spiders together is something the demo-derby guys do. They aren't worried safety or durability.
joww3
I saw a complete 9 3/4 rearend in the Mopar Muscle magazine, cost $1840. very expensive. or a Detroit TrueTrac for around $500, still a lot of money. I'll keep looking, maybe I'll find something more reasonable.
