come to my rescue.... Skipping...
Started by Khyron, August 23, 2010, 06:38:01 PM
Khyron
O.k.. so here is the long and short, i've been having issues with the Charger skipping and backfiring... this what what i've gone through, earlier this year i was driving the car home and it started to surge, like it was skipping the ignition... I thought my carb finally crapped the bed and got a new one.. the old one was a 750, new one is an 850... so Replaced the plugs because I figured the fouled out but ater 2 times out, the problem came back... this continued to happen, i would make a change, replace the plugs, and after a few times out it would start skipping again... I brought it to a frined after about a month of aggrivation and he saw that the voltage comming out of the MSB box was low, so we replaced everything...
new distributer
Wires
plugs
MDS 6AL box
MSD Blaster 2 coil
Cap
Rotor...
Rebuild the Carb, 4150 series 850 with mecanical secondarys. 82 jets all the way around. 6.5 power valve, 34 squirter... she's running about 19 on the vacuum gadge... I took the charge rout about 4 times, and now the problem is back... when I idle it pop out the exaust.... when I drive the car surges... has power...looses power....had power...looses power.
I removed and inspected all th eplugs. the plugs are clean... as I said, they where new, no burnt crap or anything that shows it to be fouled.
The MSD power is hooked through a 10 gauge wire to a fuse box, then to the ignition relay, then to the battery. Im getting voltage through all points as 12.5 volts... should be more then enough right?
Im at my wits end... WTF is this cars problem?
Motor stats 67 440 bored .030 over
eddie RPM heads
roller rockers
torker 2 single plane intake
lunati .513 lift cam
flat top forges ross racing pistons
eagle crank
skat H beam rods
Idles at 12 degree and it 35 degree total... ignition doesn't seem to jump around at idle.
HELP ME before this freaking thing see's E-bay and I buy a fuel injected new chally! I think I included as much info as i can think of...
BTW: can plugs be fouled if they are spotless?
HERE, HERE, AND HERE.
mikepmcs
cam wiped maybe?  IDK just throwing that out there cause you seem to have everything covered.
Khyron
i would hope not, it's has maybe...MAYBE 1000 miles on it.... however, going back and reading some other posts from fireman and the rest of u guys... im wondering if maybe a valve isn't right? but they are brand new heads, bought last year in PA... but installed around octomber of last year.... would a valve issue do this? pop out the exaust and kill a cyl? ... i even had it run and pulled plug wires to see if maybe one wasn't firing, you know, listen for a tone change.... didn't help much, just have me one hell of a ZAP once .... :P
and then, if it was.... why would a plug change stop it.... then it come back. I've put 6 sets of Fing plugs in this so far LOL. Been using autolites for the eddie heads.
Khyron
I try to be thorough before posting problems ;) but this one has be stumped.
12.5 volts is low, 13.5 is more like real world. Battery, is it tested and in tip top shape? What are you running for an alt. could be MSD is getting marginal voltage/amps and your getting a cascade effect, spark weakens, cylinders load up and clear? How/what are you running for a fuel pump? If you feed from battery side (anything) you are stuck feeding when running after alt. output runs through bulkhead in and out and if battery is weak plus your drawing off it (Making Alt think it's even weaker) Get me? I'm trying to think of what you have not so far?  :shruggy: Check connectors and ground straps any all electrical. (Before giving up)
Khyron
hmm, o.k.... well the Battery is only about 5 months old... I swap it out under warrenty every year ;-) so it's reading good... The battery is however in the trunk... and it's a high volume mechanical pump...
So I think Im seeing what you are getting at, so maybe I should get some more 10 gauge wire and run it fromt the MSD <located in the front> and hook it directly to the battery? so that Im not at the rest of the systems mercy?
Ohh, Alt is a standard 60 amp, and has been on the last 3 motors, it's runnign great and hasn't been an issue before. This car has always run a MSD box since i've owned it... first upgrade I made.
Back N Black
Did you check fuel pump push rod? i had similar problems and the fuel pump push rod was worn with only 700 miles on the new build. I figured it was the high volume pump because it seem really hard to push the pump lever. I changed it out with a stock pump and new rod ans 800 miles later and the rod is GTG.
Khyron
hmm, never looked at fuel delivery, fuel was always arounf 7 psi
Khyron
I just thought, could it be a volage regulator issue, even if the MSD is hooked directly up to the battery?
Check here  www.madelectrical.com  for tips, running anything off battery side is not 1st choice in my book, specially from trunk, keep in mind the longer any wire runs the bigger it must be. My old alt. (factory) didn't charge well at idle and the back and forth discharge at idle then recharge above idle overworked everything. If (at idle) you don't have dimming headlights at night or wipers that slow when you turn the heater fan on, your OK then. A battery that young should be fine.  :scratchchin:
BigBlackDodge
Khyron
Quote from: b5blue on August 24, 2010, 06:02:08 AM
it's an old mopar. the lights dim, car doesn't charge well at idle. charges while driving.... MSD suggests being hooked directly to the battery though, it's got a built in fuze, so your saying not too?
Khyron
TylerCharger69
With that .513 lift cam.....You state that you are using roller rockers.....Is it a roller cam and lifter set up as well?  And....What ratio of rocker arms?....1.5?....1.6?   And  maybe weak valve springs?   I dunno....I'm just throwing ideas out there because these ingredients arent posted in your original post.    But I have to agree  that 12.5  is NOT optimum  but if it reads that across the board....i dont see that being the problem as you describe it as to be intermittent
Quote from: Khyron on August 24, 2010, 04:36:53 PM
no answers? :-(
My charging issues ended with a 120 amp Denso alt. kit from Mancini, no dimming or other problems anymore. I didn't rewire the car just put it in. I don't know much about your ignition system, I never used MSD. Do a search I posted pics. if interested.
Khyron
hydrolic rollers with a 1.6 lift, springs are from lunati and are good for a .600 lift. 12.5 is not running, i'll take a reading with the charger running.
The only think that makes me doubt a valve or spring issue is it doesn't do it when I change the plugs.... im so freaking confused.
What plugs are you using ? This engine has eddy heads right ?
Ideally, i would like to see more initial timing in the 16-18* range at idle and 34-35* total all in by 2500 rpm.
Khyron
Im using Autolite plugs, I can get you the actual part number... I could give her more initial... but she's at 35 total at 2500 - 3000
It seems that the issue corrects itself initially with the plug change then returns.  :P I'm suspecting a plug issue...either defective or incorrect heat range. I like the NGK BCPR6ES plugs in the e-heads with pump gas compression. These are by far the best plugs for a street motor.
Khyron
I'll be more then happy to buy the new plugs.... but this wasn't ever an issue until earlier this year..... but i'll try anything once, I will get those plugs tommorow.
anything else you can think of for me to do as well?
I can se ethe heat range thing.... but for the defective, 6 sets would need to have been that way... Im hating the car at this point.
It could be many things ; defective cap or rotor, bad ignition wires, reluctor in the dizzy etc....
Run a resistance test on your ignition wires and see what you've got. You should have no more than 250ohms per foot.
keep us up to speed Jason  :yesnod:
Khyron
hmm, new cap and rotor..... brand new wires.... 3rd distributer because i kept thinking I was getting bad ones... see, this is why we're so confused....  I'll run a resistance test to be safe though.
ohh and second carb ;)
flyinlow
I agree with Ron on the NGK BCPR6ES plugs. I use them in my eddy heads. Just changed after 15k looked good. ( 446/ E Heads/Lunati 60303)
Ignition : put an electrode ( bolt will work) in the coil wire hole in the distributor cap . Hold the coil wire with a grounded and insulated pliers. Hold it against the electrode and have someone start the engine. See how far the ignition will jump. My MSD will jump about 3/4 of an inch with a bright blue spark before the engine dies.
My MSD starts the car while cranking when the voltage has droped to 11.8. When I go to the track I unplug the alternator and the MSD works fine on just the battery (trunk mounted optima).
I run 25* timining at idle / 36* total . I ran 15 * timming before I watched Waynes video and it ran ok that way. If you are running vacuum advance try unplugging it. I had to limit my vacuuum  advance to about 8-10 * to keep from missing/ bucking at light throttle cruising speeds
Fuel: My carter HV street pump wil fill a 2 liter in well under a minute at idle . 8-9 psi ,regualed down to 6psi. Try with the gas cap off or loose.
fuel pump pushrod I had go bad showed up at extended high power settings.
I would think a bad cam or spring would show up with a vacuum gauge. Irratic
Couple ideas anyway   :Twocents:
ionracer24
check ur pushrods and valve springs, also did u change the power valve on the carb when u rebuilt it???  those are always likely culprits for back firing, missing etc....
Real race cars have three pedals......
mhinders
Quote from: Khyron on August 23, 2010, 06:38:01 PM
...that sounds to me like a fuel supply problem. Vacuum in the gas tank? Pump not able to supply enough fuel?
Quote
I removed and inspected all the plugs. the plugs are clean... as I said, they where new, no burnt crap or anything that shows it to be fouled.
What color were the plugs? Were they kind of white indicating a lean, possibly overheated condition?
Martin
Martin
Dodge Charger 1967, 512 cui, E85, MegaSquirt MS3X sequential ignition and injection
