Who is running 112* Lobe separation on there blown motors!!?
Started by 69charger440, August 18, 2010, 12:23:05 PM
69charger440
Just curious to know if anyone with a blown motor is running a camshaft with 112 lobe separation!! I was told it would cause overheating on a gas street engine!!! We just had a camshaft ground with 112 lobe separation, so if you have any insight it would be greatly appreciated. Dont want to install this camshaft if people are having problems with this 112 lobe separation and overheating!!! Thanks!!
1969 Charger 540 Blown Hemi 1000HP, 69 Road Runner 500 Stroker 665 HP
That is bad information....my buddy runs a split pattern 112* LSA cam on the street and it runs fine...nice and cool.  :2thumbs:
His old cam was a 108 single pattern grind designed for a N/A build and he also ran that one with no issues. It worked descent too  :yesnod: and didn't overheat allthough the "experts" said that it would.  ;)
Stab it in there !  :coolgleamA:
69charger440
Well that is what I have been thinking!!!!   So here is the cam I picked out for it!!!!   LIFT .626 Intake .630 Exhaust
        Duration .298 Intake .304 Exhuast
        Lobe Separation at 112*
What's the duration at .050 valve lift ? Is this a roller or flat tappet ? What cylinder heads ? Engine combination ?
The LSA is fine and it appears to have a split pattern which is even better  :2thumbs:
69charger440
Its a roller camshaft!! I cant remember what the .050 duration was!!!! It shipped today we should get it in two days!!!
The heads are Stage 2 heads ported!!! Its got static compression at 8:1. Stock stroke at crankshaft!! Running an 871 blower!!! Havnt picked carbs yet!!!
Not sure what a stage 2 head is ? Is that stage 2 ported cast iron (stock) or stage 2 ported aluminum ?
If using stock heads the valveguides need to be trimmed down to accomodate the increased lift. You will also need good rocker arms if you want it to live on the street. Harland Sharp or T&D are you only options.  :Twocents:
69charger440
hey ron, this is a 426 hemi we are talking about!!!! Not sure if you knew that!!! But the heads a stage 2 Aluminum heads!!!!
Belgium R/T -68
I have a 112° LSA on my engle K60, now issues so far.
Per
69charger440
Quote from: 69charger440 on August 18, 2010, 10:09:41 PM
Ahhhh....a blown hemiroid huh ?  :icon_smile_big: Did you mean STAGE V heads ?
69charger440
Quote from: firefighter3931 on August 20, 2010, 09:29:52 PM
No, they are stage 2, says it right on the head!!! We have a set of Stage V, also!! But they are bare heads!! The stage 2's were complete and ported so wh went with them!!!
