welding sheet metal
Started by Lil Ben, August 17, 2010, 10:28:08 AM
Lil Ben
can someone tell me what voltage, wire speed , amprage or any thing i need to know about welding sheet metal. also do i spot weld until the panel is complete or to i leave an interval and throw beads in between?
HOTROD
GET this video, HOW TO ASAP WELD !
www.howtoasap.com  !
What the Hell-Dumass !
lexxman
 Yes you should check the web for some video. Because it depends on the kind of welder your using,you will want to weld it full. But you will also not want build to much heat in one spot. Before you do anything check on  this site.I'm not sure of the thread,but I know there was one not that long ago that would answer alot of your questions. :2thumbs:
