tci trans
Started by Grip64, August 10, 2010, 04:20:19 PM
Grip64
Looking for some advice here please fella's,
Going to be instailing a tci comp trans with a manual valve body in the next couple of week's,
Would i be correct in thinking i don't reinstall the kickdown linkage, and also when burning out at the strip, leave the trans in 2nd gear ?
Thanks for your reply's in advance  :2thumbs:
RD
1st - had a member here have a KABOOM moment with the tci transmission so be weary http://www.dodgecharger.com/forum/index.php/topic,71503.0.html
2nd - no need for trans linkage from carburetor
3rd - if you have a MVB with low band apply you "can" do a 1st gear burnout, but do not keep hitting for too long before you shift to 2nd.  it is still hard on the rear sprag.
oldkimmer
.............If it a foreward pattern, use ur kd linkage..................strip only   tie back the kd lever all the way................kim........
Back in the good old days 1968 charger rt 440 magnum . 1968  charger 383 magnum. The Beast has been Unleashed!!!!!!!!!!!!!!
