Spark plug reading
Started by BBKNARF, August 05, 2010, 11:23:08 AM
BBKNARF
After my drive around town my car wasn't performing as it should, I pulled all the plugs out and this is what I found.
I'm running a stroked 451, Holley 950cfm d.p., jet size 79 front, 84 back, 2.5 power valves front & back, Eddie duel plane rpm performer intake, Eddie heads, ngk plugs BCP6E S gaped at .045,
all MSD system, Firecore wires, total timing 36*, I know the basic plug reading but need a little help on whats going on the car was driving great at these setting before, what gives.
68 Charger, slowly in the works, 451 c.i. approx. 535 hp @ the flywheel, so far best time in the 1/4
11.21 @ 119 mph, full exhaust, stock suspension, 4:10s @ 3640 pounds.
lisiecki1
carbon fouling?  were they wet at all?
idahogrumpy
In my opinion the plugs are too cold, the engine is rich, and the timing is a little too advanced. Grumpy :Twocents:
Too much to say
Too much to do
Too tired to get it done
Too stubborn to give up
GRUMPY
Modified 73 440 Charger, 03 Intrepid SXT, 02 Neon and 2001 Ram 1500 .
idahogrumpy
You might also check your cap, rotor, and plug wires. Looks like some holes are firing better than others.  :Twocents: Grumpy
Too much to say
Too much to do
GRUMPY
BBKNARF
Quote from: idahogrumpy on August 05, 2010, 08:42:11 PM
Every thing looks good, the plugs were not wet when I pulled them, also the plugs is what they reccomand for my combo.
36* total is what my motor loves, Ive tryed it lower and higher, its a guessing game, maybe I'll try running a hotter plug  :shruggy:
Frank
The 6 series plug is perfect for that combo....don't change it. It's definately rich and there seems to be some variation between cylinders. You might have some clogged air bleeds which is richening up the mixture. Get some carb cleaner and try spraying both the idle and high speed air bleeds.
Frank, how much vacuum is your engine making at idle ? The HP carbs are designed for low vacuum and the fuel curve is quite agressive.
BBKNARF
Quote from: firefighter3931 on August 05, 2010, 11:19:53 PM
I will spray some cleaner in the air bleeds and see what happens, my vacuum is 8 at idle. The duration on my camshaft is 248/254 @ .050" lift
