Cooling ???
Started by lukendan, July 05, 2010, 12:38:04 AM
lukendan
69 Charger w/ 383. runs 160-190. At idle in gear it can get up to 200-205ish if you sit long enough in the heat. It has a redone 22" radiator. How much would installing a shroud help???
FLG
Shroud will help, though 200-205 is fine IMO.
elacruze
Quote from: lukendan on July 05, 2010, 12:38:04 AM
Adding a shroud would probably keep you pretty close to 190 sitting in gear, you're not that far off as it is.
1968 505" EFI 4-speed
Hemidog
I just added a shroud myself, and the idle temp dropped 10 degrees.
