body plugs
Started by charger01, July 05, 2010, 12:05:56 AM
charger01
Anyone know what size holes to drill for the trunk pan body plugs?
Good question.....just bought a set myself after 15 years of not having them drilled out!!
bakerhillpins
Why the heck are those things in there anyway - Did they dip the cars in paint vats and need drains?  :shruggy:
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
charger01
Nowdays the robots use some of the holes as grasping points. other ones are used to sit the panel on a fixture.  Back then I dunno, but I imagine the same sort of thing.
hemi-hampton
Quote from: bakerhillpins on July 05, 2010, 10:51:59 AM
YES
HOTROD
why put holes in a good panel  :brickwall: :shruggy:
What the Hell-Dumass !
bakerhillpins
Quote from: HOTROD on July 05, 2010, 05:23:14 PM
I'm with you. If they were only in there for the factory then why bother unless you are trying to do a factory perfect resto.
96' VFR750 (Sweet)
charger01
because it looks more like a factory trunk pan that way.  Just prefer the car to be the way it was originally built.
charger01
nobody have any idea?  :shruggy:
HOTROD
I am not getting paid for this  :smilielol: !
charger01
Quote from: HOTROD on July 09, 2010, 05:27:35 PM
thanks , you're alot of help ::)
ok just been to mesure my spare  original ones !
OEM body plugs in the trunk floor of a 69 are  1 3/4" s   &  1" , diameter that press clicks in to the sheet metal !   , there are two different types uses  rubber & plastic  , what i done when i replaced my floor ,  was to use the biggest cone cutter i could find , then just file to fit with the 1 3/4 ones ! or use an air saber saw, then file :yesnod:
charger01
thank you very much
