Need help! Mech fuel pump
Started by cougs, June 28, 2010, 09:10:48 PM
cougs
gang, I need some advice!  I just replaced a stock mechanicl fuel pump for a Carter M4589 high vol mechanical for my 68 Charger 383 but the new one is not pumping any fuel.  I fill the fuel bowl and it runs fine for about 30 seconds until the bowl runs dry.  I have a transparent fuel filter and it is dry and the line from the tank from the alternator is still dry.  Could this be the wrong pump?
The car was running fine before replacing the pump.  Any ideas?
1968 Charger 383/727  Restored to Stock!
Bet the fuel pump rod fell down and the pump lever is sitting on top of it
I would check that first
cougs
Yeah, I'll need to check.  I thought the rod stayed up there when I was installing it but I guess it could have fallen out.
By the way,  I meant the fuel line under the alternator, not from, oh man!
62 Max
Quote from: A383Wing on June 28, 2010, 09:12:05 PM
If the rod fell down,I doubt you could get the pump on. :scratchchin:
cougs
That's what I was thinking.  It can't fall all the way out as long as the plug is in, can it?
Quote from: 62 Max on June 28, 2010, 09:52:21 PM
You wanna take that bet? pump will bolt on...lever will be on top of rod...use heavy grease to hold rod up to cam
<don't ask how I know this>
wrench
Chances are the pushrod is worn out. remove the pump, insert your finger in the pump cavity, pushing up on the rod and have someone turn the engine over by hand. if the rod moves at least 1/4 inch, your cam eccentric should be ok. then remove your pushrod and measure it. there is a thread on here that gives the measurement for the pushrod
Possible....but in first post he said car was running fine before he changed pumps....how could rod be worn out when it was working before?
charger2fast4u
Quote from: A383Wing on June 28, 2010, 10:08:51 PM
i replaced my fuel pump pushrod and put on a new edelbrock mech pump that's interesting to know i'll start bein more careful to make sure that don't happen to me. i couldn't get it to bolt up when the pushrod was down it wouldn't line up it rod kept falling down. i would measure the 2 fuel pump levers that the rod pushs the new pump might be shorter and isnt contacting the rod.
tufamc
Just a thought,
I have a carter fuel pump on my amc 401, and when I installed it, I hooked up the fuel lines backwards. So it was tryint to pump from the carb to the tank!  :eek2: Just something to check out, especially sense it was running before
JR
btw... I had all rubber fuel lines at the pump location, i just mixed em' up....1 beer...2 beers...3 beers.........
69' Charger 383 4bbl, TF727.....for now......
I'll take that bet because it's a physical impossibility, the distance from the pushrod hole in the block to the back of the pipe plug is only about 1 1/2"...the pushrod is over 3" long.
Even if the pushrod could drop far enough to allow the lever to sit on top of it the pushrod would fall into the pan.
62 Max
Quote from: John_Kunkel on June 29, 2010, 06:07:14 PM
Thanks John!  ;D
Well, you believe what ya want....I have done it....
Quote from: A383Wing on June 29, 2010, 08:05:29 PM
I've seen something similar....the fuel pump arm was sitting on the side of the rod. Found this out when it wouldn't prime ; we removed the fuel pump and the arm was bent off to one side.  :P
yea..mine was on top of the rod...fuel pump arm was bent up from bolting pump on
Good, why not prove it by posting dimensions that differ with mine, if there is only a 1 1/2" opening how do you expose the top of a 3.2" pushrod?
Having the lever jammed along side the pushrod like Ron said is a whole lot different than being on top of the rod as you claim.
I didn't say the lever was on the tip of the rod...I said it was on top of the rod....lever was bent beyond repair....
Wrong time of the month for ya John??  :D
62 Max
Quote from: A383Wing on June 30, 2010, 07:45:31 PM
I didn't see the word "Tip" anywhere in any of John's posts. :shruggy:
FLG
Simple miss communication, grab some beers  :cheers:
62 Max
Quote from: A383Wing on June 29, 2010, 11:36:22 PM
You couldn't tell something was wrong while you were doing it? Wouldn't want you putting my pump on! ::)
Not really....it was back in the 70's when I did it....was not real good at mechanics back then.....but I'm gooder now
62 Max
Quote from: A383Wing on June 30, 2010, 08:08:38 PM
Gooder is better! :2thumbs:
cougs
I found the problem.  The fuel pump rod is missing about 3/8" off the cam end.  Looks like it's been wearing away for quite some time and is the likely culprit of my fuel delivery issues.
Where should I get a new one?  Can I install a new pump rod without replacing the eccentric circle?
Brock
If your car is a big block....there is no "eccentric" circle....the rod rides on the camshaft
You can probably get a new pump rod at most auto part stores...they may not have it in stock, but it should be available ......your call whether or not to put a new pump rod on an old cam....it might just wear the new one out faster
Perhaps it's your language skills, look at Ron's description....."Fuel pump arm was sitting on the side of the rod" is more descriptive than your "lever will be on top of rod". Do you unscrew a bottle cap from "the top" or "the side".
BTW, thanks for the insulting PM and blocking any reply.
