Trunk Gutters
Started by Matthan, June 27, 2010, 06:37:16 PM
Matthan
How hard is it to replace your Trunk Gutters on a 1970 Charger?
TylerCharger69
Drop Top
No harder then replacing any other body part. Depends on you level of experance. Its only metal and can always be welded up and ground down. I used an air hammer and a cut off wheel as needed. be carefull not to get into the 1/4. Then reshape where needed with a hammer and dolly, fit the new one in and weld up with a spot welder or glue and clamps. Buy the way you are talking about the side ones right? The other ones are part of another panel and will take a bit more work.
