building your own rotisserie
Started by fireguyfire, June 18, 2010, 07:36:51 AM
fireguyfire
Hey guys; got my 68 back from the frame shop and am ready to strip her down and start welding in my new metal (1/4's, floor plans). I am debating building a rotisserie to make the job of refinishing the underside easier; has anyone here done it, or have plans on how to build one? How can you do it inexpensively but safely?
'66 Coronet 500
'68 Charger
'69 Sweptline Adventurer pickup
'56 Dodge Regent
Darkman
I have some detailed plans in pdf format if you want them. I can email them to you if you want them.
Make it idiot proof, and somebody will make a better idiot!
If you think Education is difficult, try being stupid!
gschmidt211
I was going to do the same thing.  I was thinking of this one:
http://members.tripod.com/mopar_roadster/body_rotisserie.html.
I also downloaded an article from a guy who built his own and wrote a detailed plan of how he did it with a cut list.  The article also has a lot of good pictures documenting his process.
Click this link to download a .pdf copy of the article.
http://files.me.com/gschmidt211/izs9j1
1972 Charger Rallye
2014 Ram Outdoorsman 3.6L 4x2
1978 D100 Utiline Standard Cab
gschmidt211
Hello Darkman,
If you would not mind, I would like a copy of your plans also.  I am also looking to build one, and as stated above, I have a few plans, but more would be better for comparison.
My email is gschmidt211@me.com.
Thank you.
1972 Charger Rallye
fireguyfire
Roughly how much does it cost to build one? Guys that have done it, is it worth it?
'66 Coronet 500
'68 Charger
'56 Dodge Regent
vancamp
Quote from: fireguyfire on June 18, 2010, 12:43:58 PM
worth it definetly built one for a 66 satellite i think i had $150-$200 in materials that is without hydraulic jacks which make infinetly more user friendly when lifting or lowering the car.
gschmidt211
I priced out the materials for the one I am thinking of building and I think I can do it for between $400 and $500.  That is mostly steel cost.  That is also based on having free access to all of the welding, cutting and painting equipment.
1972 Charger Rallye
Magnumcharger
Here's an idea...pay attention now.
Look up. See the blue bar that says Home-Help-SEARCH....yes that one.
Hit the search button, then type in "Rotisserie".
You might just find what you're looking for - right here on this forum.
In fact, I know you will!
1968 Plymouth Barracuda Formula S 340 convertible
1968 Dodge Charger R/T 426 Hemi 4 speed
1968 Plymouth Barracuda S/S clone 426 Hemi auto
1969 Dodge Deora pickup clone 318 auto
1971 Dodge Charger R/T 440 auto
1972 Dodge C600 318 4 speed ramp truck
1972 Dodge C800 413 5 speed
1979 Chrysler 300 T-top 360 auto
2001 Dodge RAM Sport Offroad 360 auto
2010 Dodge Challenger R/T 6 speed
2014 RAM Laramie 5.7 Hemi 8 speed
fireguyfire
Yeah,yeah I know about the search function and have read a bunch of old threads; steel prices have changed alot, and being an experienced woodworker I am intrigued by guys that have built ones out of wood; anyone here done that and had success? Searched the net and it seems fairly common.
'66 Coronet 500
'68 Charger
'56 Dodge Regent
Domino
Quote from: fireguyfire on June 19, 2010, 05:14:19 PM
Here's plans and pics (posted on FBBO too):
The bill for my steel was $340 (not cut) add about $200 to that if you want everything cut and ready to build. You should not need to machine anything b/c 2.5" tube 1/4" wall fits inside 3" tube with 3/16" wall for the greased pivots.
I cut up an old golf cart (FREEBIE) for the wheels/tires/axles. This will get the rig from shop to blasting area outside. The front wheels will always turn/point parallel to a tow bar hitched to my ATV. The rear wheels are fixed axle, like a hay wagon setup.
Can add/substitute caster mounting plates too... for "improved surfaces" or use cheap wheel dollies to maneuver around inside shop.
The basic size is from Harwood's plans, but I changed a few things after looking at some other designs. It will come apart for storage or transport and has height adjustment.
451-74Charger
If you dont have a welder, you could make it out of wood like this chap
http://www.nastyz28.com/forum/showthread.php?t=98675
hemi-hampton
Last one I welded up was around $500 in steel & cut. Thats was about 10 years ago. My Advise is use a heavy duty 220 mig or Arc Welder better yet. The 110 I used fried & burnt up after continious hours of use & hard to penetrate thich steel with a 110 unless turned up to max.  LEON.
6pkrtse
I built mine similar to the tripod rotisserie. I had about $240.00 into mine with paint, casters & hardware. I have many car buddies wanting me to build more. I have thought about it.
1963 Belvedere 413 Max Wedge
1970 Charger R/T S.E. 440 sixpack.
1970 Challenger R/T Drag Radial 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Road Runner 383 4 BBL
1974 Chrysler New Yorker 440 4 BBL
1996 Dodge Ram 2500 V-10 488 cu in.
2004 Dodge Ram 3500 CTD Dually 6x6
2012 Challenger R/T Classic
Hudson Hornet !
I am an autobody teacher at a vo-tech school and can see the merits of a rotisserie, but do not forget the body cart. The last car we did was on the spit for a week, but we used the cart throughout the build! Also, the body cart will support the car better when you have major panels to cut out- no sagging.
You've never heard of a Hudson hornet ? !
Tilar
I hadn't thought of a cart. I have some pretty nice plans for a rotisserie that I intend on taking down to the local vocation school and have them build it. I wonder if there are any plans of a cart floating around anywhere?
Dave
Hudson Hornet !
Since the weld shop is right next door to mine, we had them build it.  Didn't use any plans, just saw some on the internet and made it adjustable, that way it will fit anything from a truck bed to a jeep body to a 69 Charger!
69rtse4spd
Scored one last week for $400.00,  :2thumbs: guy used it one time. No jacks but can be mounted easy enough since the brackets are there. He paid about 900.00 for it, so now I got one to use as a pattern if I want to build another one. Of course if you build one you have to figure in the time factor, but that usually is not a problem. If you do build it, do not go cheap when it comes to a gusset here or their, spend a little extra money on steel to make it safe, good luck which ever way you go.
Domino
Quote from: hemi-hampton on August 03, 2010, 10:28:40 PM
My 110 did OK (it's an old MW), I used a 220 arc/stick on the "T" arm and the round connections for good penetration, cleaned up, and came back with 2 passes with the 110 mig along the "toe" of the stick weld.
The frame has plenty of weld length with the gussets that the 110 is OK.  Here's a pic: 0.030 and machine set with heat all the way up, and wire speed as slow as possible to max out penetration.  You can also use a torch to preheat the area and that helps penetrate and helps the weld pool flow/ flatten out instead of building on top of cold metal.
hemi-hampton
Did you do yours all at once in one day. I had the heat turned up to max & fried/burned up/melted a Diode. LEON.
Domino
Quote from: hemi-hampton on August 06, 2010, 07:05:45 PM
Yeah, it'll burn wire on max for hours straight.
Although it's old, I think it is a "production" quality welder vs. hobby.  Takes the large wire spools.  I got it used in trade for a debt, but it has worked very well, surprisingly enough!
Prior I had a small 110 mig and it would just shut off after about 15 minutes.  I'd drink too many beers with that thing waiting for it to cool down!  :cheers:
Tilar
Quote from: Domino on August 06, 2010, 07:34:56 PM
I hate when that happens.  :lol:
Dave
motorcitydak
Sorry I am late to post here but I just took my car off the one I built for it. Grand total was $160 to build it. Here is a pic of it, this is the front one. The back is the same except for the bracket that gets bolted to the car
96 Dakota, custom everything 4x4, 5.7 HEMI
'68 charger project
[OO!!!!!!!!!OO]
charge69
No pic right now but this is the 3rd MOPAR that has been on the home-built rotisserie and it has served us well each and every time.  It is completely adjustable and has had a '74 Chally, a '69 Roadrunner and, finally, my '69 Charger mounted with comparative ease.
My friend has all the welding components (mig, tig,stick,spot and even a plasma cutter) to make it right and they just work!
Domino
Two weekends of tear down to get to a bare shell and the rotisserie gets its first test.
So there's proof for the previously posted plans  :cheers:
fireguyfire
Next issue; what's the best/easiest way to get a car up onto a rotisserie once I've built it?
'66 Coronet 500
'68 Charger
'56 Dodge Regent
