headlight door motor
Started by Rockyrocco, June 16, 2010, 01:50:02 PM
Rockyrocco
Ihave a 70' dodge charger with electric motor for the headlight doors. It has a manual opener but it sure would be nice if it worked, any ideas on how to repair the motor.
limey
Have you isolated the motor as definitely being at fault? In my experience, there are so many weak spots in the circuit (bulkhead connector, bad ground etc) that would be my starting point. Then if it is, take it out of the car, onto he bench and strip it down, checking the connection withing the motor casing,the brushes etc.
Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. -- Albert Einstein
Topher
Topher
67 Charger 383-4spd "the Dawg"
www.headlightmotorman.com
