Original coil swapping to MSD Blaster 2 coil - original capacitor???
Started by Charger´69, June 14, 2010, 02:10:03 AM
Charger´69
I asked this in my project thread but anyone didn´t answer so I put this here if someone notices this..  :icon_smile_blackeye:
So, I swapped my original coil to MSD Blaster 2 coil. My original coil had some kind of capacitor connected to it´s + terminal and it was grounded to intake manifold. So, should I use that capacitor with new MSD coil or not?  :scratchchin:
MSD instructions doesn´t say anything about it, it says only that I should use 0.8 ohm ballast resistor and I used original 1.0 ohm ballast resistor because I didn´t have that 0.8 ohm resistor.
I have some kind of original electronic ignition and electronic voltage regulator. And car is '69 Charger with 440cid engine.
I would appreciate if someone answers this question  :cheers:
Plymouth Fury "Christine's Sister" 4x4 6-71 1959
Dodge Charger R/T 440cid 1969
Pontiac Trans Am T-top SuperBandit 400cid 1978
Jeep Cherokee Renegade 4x4 3.7 2006
y3chargerrt
You can leave the cap off. It was installed by someone as a filter probably for radio noise.
Charger´69
Quote from: y3chargerrt on June 14, 2010, 06:06:07 AM
Thanks!  :2thumbs: I was wondering that myself too, because original wiring diagram doesn´t show this capacitor at all  :shruggy:
