255 spare
Started by tan top, June 05, 2010, 01:29:01 PM
 :scratchchin: having a change of plan with wheels & tyres  !!  cant get a 255 x 60 R15  on an 8" wheel to fit in trunk in stock location !! ,  :ahum: thought they fitted !!    :icon_smile_blackeye:    but any bigger did not  :scratchchin:
dont tell me i welded the trunk pan in wrong 21 years ago too high at the back !!  :slap: ;D :eek2:  any one have one in the trunk ? appreciate any help ??  :cheers: :popcrn:
Nope.....you aint getting that size in there.   235/60/15 is the largest i was ever able to fit....
oh right !!  235 is the max  :scratchchin:  thanks for the reply  Chris ! been appreciated  :cheers: :cheers: :yesnod: :2thumbs:
hmmm will have to have a think !! wanted 255s all round & a matching  spare :think:
My opinion here...all you would need is the same "height" tire (or "tall equivalent")...width of tire or wheel does not matter for spare....all you are gonna use it for is emergency, right?
:Twocents:
Quote from: A383Wing on June 05, 2010, 05:57:26 PM
:Twocents:
yes i see what your saying & your right :cheers: :cheers: :yesnod: :2thumbs:
  !!  but i'm nutts like that !! like all tires the same ,  get a puncture 100 miles away going to a show , drag strip etc etc  got to sit there all day with an odd size tire & or wheel !!
nothing wrong with the other way!!  different spare !  but not for me
Quote from: tan top on June 05, 2010, 05:28:26 PM
Matching spare?  Ha....heres my matching spare....
and I have a AAA card in my wallet (towing) ;)
Quote from: Just 6T9 CHGR on June 06, 2010, 05:49:08 AM
:coolgleamA: :yesnod:  :scratchchin:  think i'll put the 235   in the trunk then   ;)  :yesnod: had a G70 14  as a spare before for years !
Neal_J
Same dilemma here.   I'm running 255-60-15 in front and 275-60-15 out back, both BFG-T/As on Magnums.  The spare is a 14" tire on a Rallye rim.
I initially approached the problem from the "what's the widest spare that will fit?" approach.  However, since neither will fit, I'm now more interested in the "what's the best height tire that will fit?"
Using the suggestions per this thread & the specs per TireRack.com, my tires are 27.1" and 28" tall, F&R respectively.  Although the 235 will fit, I think I will go with a either a 225-60-15 or 235-70-15 because the height of the tire (27.3" or 27.8", respectively) comes the closest to splitting the difference between the height of the two tire sizes.  Mount it on a Magnum and my life is complete. OK, slightly closer to complete.
In a pinch, I'd go The Chris Route & use USAA for towing.
However, I like idea of having the option of having a usable spare just in case.  I'm a belt & suspenders guy for stuff like getting stuck on the side of the freeway...
Thanks all!
Neal, remember this information:
Front:  255-60-15, 27.1" height
Rear:   275-60-15, 28.0" height
Midpoint:  27.55" (ideal spare height)
BFG T/A Spare Options, per TireRack:
a) 225-60-15, 27.3" height
b) 235-70-15, 27.8" height
(Since both are 0.25" off ideal height, go with the 225)
 well in the end went to all that trouble of making sure i could run 255x60 R15
at all four corners  , on an 8 inch  wheel , with all four having the same back space , & more importantly ! giving the (look ) i was after , with out any rubbing ! ,i made my own spare tire hold down bracket , & located where i could have a 255x 60R15  on a  15 x 8 wheel  as close to the stock location ! ,  only required drilling two extra holes in the trunk floor :yesnod: so i have what i wanted all 5 tires & wheels the same size  , &  can be swapped front to back & spare wheel as required   :yesnod:
375instroke
Quote from: Neal_J on August 18, 2010, 04:47:44 PM
Thanks all!
In this example, I'd go with the tire that matches the rear tire diameter the closest to reduce the wear on the Sure-Grip and spider gears.
