Steering column, restore
Started by PatrickPeeters, June 05, 2010, 12:15:44 PM
PatrickPeeters
1968 Charger, columnshifter
Does any one know what the 2 nuts and bolts in the top steeringwheelhousing are for?
Can't tighten them all the way, can't remember that they where loose.
When you look on the otherside, the bolt have a square head and they lock in the housing.
figured it out, when you put it all together the nuts need to be tighened and fits perfectly.!!!! :2thumbs:
Patrick  :punkrocka:
Rolling_Thunder
holds that piece to the shell below it...   what a PITA - 1969 they did it differently    :2thumbs:
y3chargerrt
69 column shift columns have those same bolt/nuts.
PatrickPeeters
Thanks problem solved, think it looks pretty good now....
The before and after (not yet assembled dough)
Patrick  :punkrocka:
