hemi pick up
Started by Matthan, May 03, 2010, 09:05:01 AM
Matthan
can you use a hemi oil pick up in a 440?
Quote from: Matthan on May 03, 2010, 09:05:01 AM
The block has to be modified if you want to use the 1/2in hemi pickup on a 440.
idahogrumpy
Yes, but the pick up hole in the block has to be over sized and tapped to 1/2 pipe at the correct angle.
Too much to say
Too much to do
Too tired to get it done
Too stubborn to give up
GRUMPY
Modified 73 440 Charger, 03 Intrepid SXT, 02 Neon and 2001 Ram 1500 .
Also, there are two different length Hemi pickups so the oil pan must be the same depth as a Hemi for the year pickup used. IOW, use a Hemi pan on the 440.
