Low tension hood springs
Started by J-440, April 30, 2010, 09:12:37 PM
J-440
  Evening all.  Would the low tension hood springs used on the T/A Challengers and AAR Cudas fit on a B-body's hood hinges?  I know that the B and E bodies shared the same inner sheetmetal from the firewall on up.  What about hinges and springs?  Thanks again.
68 R/T, 440/727 6-speed, SC G-machine...black suede
RestoRick
Yes, the springs will fit.
The hood hinges E-body vs. 71-up B-body are very similar,
but not identical. The B-body has shorter length adjustment
slots in the base.
The pre-71 B-body hood hinges are a different animal, but
do have the same spring length and in fact there's some springs
used on both E & B-body.  Spring diameter, coil size & wire diameter
varied by application.
Rick
J-440
 Thanks Rick, preciate the help! :2thumbs:
