quasimoline paint
Started by towscum, April 23, 2010, 01:10:41 AM
towscum
should i paint this stuff on bare metal, or on primer.for lower control arms.i got the paint from rick kreuziger it is the stuff that dries.
1969 dodge charger 440 4 speed
If it's the golden waxy stuff it can coat anyway you want. Search here on LCA's to see lots of photos of how others have done it.  :2thumbs:
It should have come with a tech sheet (at least I would think so) but it's best to ask Rick. I don't think that primer would be a good option because that stuff is somewhat clear. According to the description:
"Darkness & coloring will vary with number of coats applied and color of control arm."
And:
"Can also be used to accentuate the coloring of some cast iron parts."
Maybe use a good coat of "steel" colored paint first?  :scratchchin:
towscum
ok, thanks for all your help.
