Lets see your picture of how you mounted a MSD system!!!
Started by khodne, April 12, 2010, 09:07:50 AM
khodne
I am about to install a MSD Digital 6, Blaster SS coil, and MSD distributor.  I am looking for pictures of how others have installed their's.  I have mocked up a couple of different ways but haven't found one I like, so I am looking for some assistance.
aifilaw
I put mine under the heater box. no pics though.
I did it back when drag racing a lot, to keep the heat off of it, it was partially visible, but didn't really interfere with the toes of the passenger.
'72 B5 Metallic Blue Hardtop
1968Dodge
I think if I ever use one I'll put it under the battery tray. I've heard of people putting them in the glove box? Not sure if I like that idea but it would be invisible.
'68 Charger R/T. Mild 440, 3.54 Dana.
Rolling_Thunder
I have put them under the battery tray along with relays for the headlights - makes the most sense to me - keeps it outta the way and out of sight.
68X426
Mine's in the glove box. Stays clean and cool. Less stuff in the engine bay. :icon_smile_cool:
We Want to Help You.
1958 Dodge Pick Up, 383, loud
1966 Dodge Van, /6, slow
Hemidog
I don't have one, but the place I would put it is the passender side footwell/firewall, beside the heater box as aifilaw said.
I think NorwayCharger put his inside the passenger fender, behind the rear splash shield.
hemigeno
Another place to hide the box is under the console (if you have one) in front of the shifter.
AKcharger
werner
Just mounted mine on Sat. Passenger fender behid rad support down low.Right behind horns on 69 charger. Wanted to keep the firewall clean looking. Will try and post a picture tonight.
1969 dodeg charger, 528 hemi ,Tko 5spd.
bill440rt
I mounted it under the driver's seat in my '68. Ran the cable under the carpet & out the unused 4-spd hole grommet in the firewall.
bill440rt
Here's a close-up shot while putting my '69 together. My dad made a nice, neat bracket bracket out of polished stainless steel to mount the MSD on the firewall. I mocked it up using some cardboard, & he bent it on a brake out of stainless.
It uses the unused factory holes for the ballast resistor & voltage regulator to mount the bracket. I'm running a one-wire alternator with a built in regulator, so I didn't need the firewall mounted one. Even clears the 6-pack air cleaner.
:Twocents:
BBKNARF
68 Charger, slowly in the works, 451 c.i. approx. 535 hp @ the flywheel, so far best time in the 1/4
11.21 @ 119 mph, full exhaust, stock suspension, 4:10s @ 3640 pounds.
694spdRT
Mine is in the right side upper cabinet of the garage.  ;)
Hopefully it will be moved to another location in the near future.
1968 Charger 383 auto
1969 Charger R/T 440 4 speed
1970 Charger 500 440 auto
1972 Challenger 318
1978 Ramcharger 360 auto
khodne
Quote from: 694spdRT on April 14, 2010, 01:36:13 PM
Mine too.
Rolling_Thunder
Also if you havent purchased your MSd box yet I highly recommend the 6AL2 - it is significantly smaller in side and has a built in 2 step rev limited
khodne
A year later and I finally have the MSD parts all mounted and hooked up.
Charger-Bodie
I mounted mine in the area ahead of the drivers door hinges.
mopar0166
That must of been a fun install i hope you had the fender off.   Im planning on using my glove box area for that suff
Charger-Bodie
Quote from: mopar0166 on April 01, 2011, 02:49:07 PM
The fender was on. The splash shield was off though. Very easy actaully.
NorwayCharger
Quote from: 1HotDaytona on April 01, 2011, 02:33:50 PM
I did the other side..
AKA the drummer boy
http://www.pink-division.com
six-tee-nine
That's really cool but wont that stuff get wet when driving in the rain.
.....And dont come telling me you dont drive in the rain
I prefer to move those electric things indoors....
