Bull's 68 Charger restoration thread
Started by bull, March 15, 2010, 02:39:19 AM
squeakfinder
    Been burning the midknight oil have we?  :popcrn:  That sure looks nice.  :2thumbs:
This reminds me, I need to get off my butt and start working on something today..
69*F5*SE
The Charger's going to look sweet Bull.  I see you added a cross bar to your rollers.  What are you going to apply to the inside of the fender wells etc. before undercoating?  Again, the body looks sweet.   :yesnod:  Ted
Belgium R/T -68
Nice progres Curtis :2thumbs: You will be driving before me. :yesnod:
Per
bull
Quote from: 69*F5*SE on May 15, 2010, 01:53:41 PM
What are you going to apply to the inside of the fender wells etc. before undercoating?    Ted
You probably know this already but that cross bar is there so I have a place for the floor jack and/or cherry picker to be able to get it off and back on the jack stands. Haven't tested it yet but I think it'll work.
As for treating the inner fenders I've been thinking about that and I'm not quite sure what I'm going to do yet. I have a combination of bare metal (a few small areas from scraping), rust, factory primer, paint and residual undercoating from the spots where I used heat to get it off. Here's what I'm thinking right now: wire wheel/brush the loose stuff off and then roll the car outside and power wash the outside of the inner fenders to get all the grime out of the nooks around the UCA suspension brackets. Then push it back inside to dry and coat everything with SEM Rust Seal before scuffing it, priming it and painting it black with a small roller. Or scuff it first and then use the SEM stuff. Then I'll make sure all the holes and nice paint areas are taped off and wheel the car back outside to shoot the undercoating. I'm open to alternative suggestions though.
Quote from: Belgium R/T -68 on May 15, 2010, 02:12:18 PM
Per
Well, I'm not going to hold my breath because previous well-laid plans have been shot to hell more times than I like to remember but hopefully next summer it'll be rolling under its own power. :2thumbs:
Belgium R/T -68
I know what you mean. It's like Neal said to me (b5blue), the last 10% will take 90% of the time. I have brakes and wipers
that doesn't work and a trunklid that doesn't fit, a heatercore that leaks and 100 of small adjustments but I guess that's what they call a project. :lol:
Per
69bronzeT5
Thanks for including those pictures of the dollies Curtis......I'm about to build some for my Coronet. The pictures you posted are a big help! :cheers:
chargergirl
Trust your Woobie!
bull
Quote from: 69bronzeT5 on May 16, 2010, 07:01:03 PM
You're welcome.
Quote from: chargergirl on May 16, 2010, 08:19:36 PM
The car is beautiful.
Thanks. :2thumbs:
aone415
This Charger right here is a one of none, that means none before it, none to come.
bull
I haven't updated this thread since May so I thought I'd do that today. As usual things took longer than I had hoped and we had kind of a lousy summer weather wise. Spring was very wet (unusually so even for the Northwest) and summer didn't amount to much. Needless to say I wasn't able to wheel the car out and do some of the stuff as often as I'd hoped to do.
After consulting with Brian a few times I settled on Chassis Saver as the magic stuff to coat the inside of the front wheel wells. If you look back at pages 1 and 2 you'll see all the "before" pics and the scraping I did to get the undercoating off everything and that's where I left off. Scraping was just the beginning because I had to go over it all with SEM Solve (basically the same as 3m General Adhesive Remover) to get all the residual goo off the metal. What remained was paint, primer, bare metal and rust, all of which got covered with Chassis Saver. It turned out nice. One paragraph doesn't really do it justice because it was a lot of work. I even had to rent a dehumidifier to scrub the air when I finished it up because it was raining and this stuff is sensitive to humidity.
Be right back to post more. Gotta put the midgets to bed...
PocketThunder
Damn that car is looking very very nice!   :yesnod:   :yesnod:  I remember when you bought it.
After going thru (restoration on) a couple cars myself in the past 15 years i can understand your level of detail but, man arent you wishing you were driving the car by now?   :drive:
"Liberalism is a disease that attacks one's ability to understand logic. Extreme manifestations include the willingness to continue down a path of self destruction, based solely on a delusional belief in a failed ideology."
bull
Quote from: PocketThunder on September 27, 2010, 10:56:05 PM
Every day. :rotz: But, I really only want to do this once so I don't know any other way to accomplish that other than to do it thoroughly and correctly. I think things would have moved faster if my foresight was half as good as my hindsight. And if my pockets were deep and full.
Anyway, I always have a bunch of other little projects running alongside the big ones. Mostly it has to do with restoring little bits and pieces. I took a bunch of stuff to a buddy's shop where he's got a real nice media cabinet and I blasted the E-brake mechanism, the throttle mechanism, the rear license plate light, the front license plate bracket and a bunch of fasteners. I also went to the hardware store and auto parts store to get some new fasteners in zinc and stainless. Here's some before/after pics along with some other odds and ends.
I got the power steering pump pulley back (it was MIA for about two weeks thanks to the sandblaster) and got the pump assembled and on the engine. I also got the manifolds ceramic coated and the throttle and E-brake mechanisms were blasted and plated with electroless nickel. The rest of the fasteners were plated with zinc and the painted stuff was done on the days when the sun was shining. I wonder how much faster this project would progress if I lived in Arizona?
bull
 :icon_smile_cool:
bull
bull
Here's those engine pics...
Bob T
Old Dog, Old Tricks.
6pkrunner
XS29J8
Looks like calendar material to me!   :2thumbs:  Great work Bull!
:cheers:
Steve
HEMI 68 CHARGER R/T- 4-SPEED- 3.54 DANA- PP1 RED- BLACK VINYL TOP- PEARL WHITE UPHOLSTERY-STRIPE DELETE- AM 8 TRACK- NON CONSOLE- DRIVEN YEAR ROUND IN SOUTHWEST FLORIDA http://900z1.multiply.com/  http://kawasaki-z-classik.com/index.php  https://spreadsheets.google.com/ccc?key=0AmY22PaMZ1H3dFczVWR2ZlJaX1BvTDFIVUdUZVlseWc&hl=en&authkey=CPi1hp8J#gid=0
Charger-Bodie
Its really looking great Curtis! Keep it up.
lilwendal
Bull... Really coming along now and looking great!!!!!! Keep the pics coming :2thumbs:
FlatbackFanatic
Flatback Fanatic, Kurt  , MN
super_dave
Looks awesome...makes me excited now that my car is finally getting close to the stage yours it at....I see I have much work to do!
twodko
Bull,
Your car is looking better and better! Its all about details for me too.
That 10% - 90% thingy is dead on.
RIDELIKEHELL
AMD POSTER BOY
