Lean Burn
Started by Lizey, February 28, 2010, 09:56:12 PM
Lizey
how do you ditch the lean-burn system on a '77 360 4 bbl.??
1977 Dodge Charger SE - Sold 4/18/15
2013 Chevrolet Camaro RS
1993 GMC K1500
1943 Farmall A
flyinlow
Install an eletronic ignition distributor ,wiring and control box. Put a nice 4bbl and intake on. If you already have a TQ you could rejet it.
it is an easy swap , dark blue is your 12 V switched wire you need as single ballast to the coil & a 4 pin ECU
