in the NUDE
Started by SFRT, February 23, 2010, 05:00:43 PM
SFRT
would that slide into my dana 60 case?
Always Drive Responsibly
Uploaded with ImageShack.us
Dans 68
Quote from: SFRT on February 24, 2010, 01:15:19 AM
In a word...no.   :rofl:
See your car at MATS next year!
Dan
Ryan
69 charger r/t Triple Black
   572 HEMI, Passion 5 speed, 4.10 Dana under construction
2014 viper TA
cobramike33
What order did you replace sheet metal in the rear?
SFRT
sort of all at once, with multiple test fittings etc....got to slide the sail panels up under the roof first then sort of fit it all together front to rear everything got fitted with just clamps, then again with screws, then the welding...but all of it not just pieces. just pieces it will not work.
SFRT
allright..yesterday handblocked the first filler coat of primer with stink block, then shot 3 more layers of top primer..that will get blocked out today, then more primer tonight, then a wetsand before the paint.
the stinkblock ( or grille block) is pretty great. Its a coal and sulfur based material that crumbles and self-forms and it sort of varies from an 80-120 grit effect. Rolfe likes the old school shit, and it works great.comes in slabs and you just saw off the right sized piece.
SFRT
SFRT
if all goes well, the car gets painted tuesday.
I am using a new paint, it's a lacquer based single stage semigloss black. we shot some test panels and it flows real nice. manufacturer claims it wont chalk up under UV light. its some sort of industrial use paint.
some people will ask, 'why after all the metal work would you not do a shiny paint' and the answer is:
1. the 7500 bucks that would cost is better used on a nice Richmond drag racing level 5 speed manual transmission.
2. car is a daily driver and will see some drag strip time, so that shiny paint would get ruined right away,wasting that money.
jaak
I have read about using those stink blocks (aka grille bricks) before, never tried it though. I hear its the bomb for blocking complex surfaces.
Keep up the good work!
Jason
looking good !
never heard of then blocking bricks before  :slap:!
:popcrn:
SFRT
they work friggin amazingingly.
lexxman
It's looking good,It will be nice to see some color.on it.
SFRT
some finishing touches before we paint tonight:
corners:
lexxman
It's looking nice ,now won't paint it with the corneras on will you?
SFRT
Brock Samson
 lookin good frank,.. general lee i think chargers were made to reflect light... but primer suits you man. I think you should put a smoke hangin out of the drivers' side grill..  :apimp:
Patronus
cool to see someones else's at the same stage as mine...exactly actually.
'cept I think I will let mine sit for awhile, maybe outside during that days to heat and cool a few times...
to weather so to speak... Any advice on the nuts for those corners? as they don't seem to hold well via the tapered alum?
what are you thinking interior? custom dash/gauges?
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
SFRT
re-install my stock black interior. radio delete. 4 speed console delete. no weird gauges, except for my digital tach that looks like a stock one from Restorations by Julius.
Patronus
mine:
'08 CRF 450r
'12.5 450SX FE
ktneifert09
How long can you keep it "in the nude" without worrying you're going to paint over micro-corrosion which grows into macro-corrosion?
Plans are useless; planning is indispensible.
Especially with an old car!
SFRT
not worried at all. the shop is bone dry at all times and everything got a real good going over.
SFRT
ok...3 coats of primer and 1 coat of sealer and rolfe applies the first coat of paint:
this will dry over the weekend then the whole thing gets nibbed with 1000 grit and a final 2 coats will be applied...badges for test look only...
Dans 68
She looks great, Frank! Keep them progress pics coming!  :2thumbs:
Dan
SFRT
its starting to look pretty good. I may have to rename the car from The Scow to something else now that it is bondo free.
maybe Ghetto Warrior..... :D
lexxman
It's looking good so far. :2thumbs:
