Duel electric fans
Started by J-440, February 15, 2010, 07:34:34 PM
J-440
  Anybody running a duel PUSHER electric fan setup?  Also was wondering how much room is available between the core support and the grill assembly.  I don't have the front end on my car installed so I am needing some specs.  I realize you can have the radiator mounts custom made and this pushes the radiator forward or rearward.  But overall, how much space is in between the core and grill?  Thanks again.
68 R/T, 440/727 6-speed, SC G-machine...black suede
RCKSTR
i have found the 6 or 7 blade clutch fan to be far better at cooling than any electric setup
J-440
  Well the car is already setup to run electric fans with the radiator and I need at least 2500 cfm to keep the car cool.  But my main concern is front end space since pusher fans will be mounted outside of the core.  From pictures, it looks as if there is at least a foot of space from the core to the back of the grill.  Am I close?
sounds about right , Chargers had more room than Moat Mopars
bill440rt
I'm running a dual Flex-a-Lite PULLER fan between my rad & engine. I had not choice due to clearance issues with the thickness of the radiator. I would have much preferred to run a clutch setup, but the clearances were too tight.
Pulls 2500cfm, and I was on the phone with Griffin to make sure it would be sufficient to cool with my rad & engine combo. They assured me it would.
The fan setup fit great with plenty of room, too. A puller fan is more efficient than a pusher, so you might want to consider one if possible.
:Twocents:
J-440
  Alright, thanks again guys, ya'll have been a big help. :2thumbs:
six-tee-nine
I'll be using electric fans too, hovever I'll be using a 28 inch wide rad (don't know the thickness yet). I was advised a dual electric fan setup by our mopar shop but that would be one large puller fan and one large pusher fan. So technically there will be a fan on both sides of the rad.
I might be using the painless kit to make them work.
The puller fan would be for normal use and the pusher fan would kick into action when things get really hot. Altough I have no idea how this setup will work, i'd trust them guys since they use this setup all the time in their shop.....
I'll be picking up my stuff next week maybe i'll snap some pictures if i get the stuff home.....
flyinlow
dual 14 inch 2900 cfm fans set up (5800 cfm total, 18 amp draw)
J-440
  Flyinlow...what's your temp when you're sitting in traffic?  Since you don't have a fan shroud, the only area of the radiator being cooled is where the fans are.  That is a lot of unused space.  But hey, if it works then you're doing good. :2thumbs:
flyinlow
Quote from: J-440 on February 19, 2010, 08:42:03 PM
Temp stays right in the middle or slightly left (cooler)  180* thermostat. Fans cycle in traffic ,unless its 90* + outside.
I can turn the fans on when ever I want, So on hot days in traffic I run them continously for airflow thru the engine compartment.
The fans are staggered up/down ,so every tube in the Radiator is cooled by a tleast one fan. Mostof the tubes see both.
They dont run  above about 20mph or in cold weather.
redmist
a lot of guys in the offroad industry are pulling junkyard electric fans with shrouds off of the Ford Taurus cars and wagons. They cool the Big Block guys at crawl speeds and up some nasty stuff with no problems.
Just a thought for the folks trying to save money. Plus the parts are available if a brake down happens.
It's a Two speed fan with a temp switch.
JUNKTRAVELER: all I've seen in this thread is a bunch of bullies and 3 guys that actually give a crap.
mauve66
alot of people i know have used the fan off a Lincoln (mark8?) with very good results
Robert-Las Vegas, NV
NEEDS:
body work
paint - mauve and black
total wiring
PW
PDLKS
Tint
trim
alignment
six-tee-nine
I dont know but honestly, I think if you want to go trough the hassle of converting from a viscous fan to electrical ones, then you schould do it right an at least built a shroud for them fans  :Twocents:
mauve66
you guys going to the aluminum radiator don't for get the thingy that keeps the bad reaction away between the aluminum and the steel, damn i wish i could remember what its called :brickwall: :brickwall: :brickwall: :brickwall:
NEEDS:
body work
total wiring
PW
PDLKS
Tint
trim
alignment
BigBlackDodge
flyinlow
jesterCT
A few days ago I saw a TV show where the "pimp-my-truck"-guy said, it is possible to increase the fuel efficiency up to 5MPG.
Does somebody has some experience with this?
Is this true?
six-tee-nine
Quote from: BigBlackDodge on February 22, 2010, 08:00:56 PM
Galvanonic corrosion. :yesnod:
BBD
Really???? time for me to get wiser......never heard of the term. But why do modern cars use aluminum rad's with the same engine specifications?
J-440
  Mauve...I think it looks like an elongated brass football thingy that slips inside your upper radiator hose?  Also, some wellnuts are needed to bolt the aluminum radiator to the steel core support b/c aluminum expands and needs a little movement.  As far as better gas mileage...sounds like a ricer who convinces himself that his Folger's coffee can exhaust pipe increases hp. :lol:
flyinlow
Quote from: jesterCT on February 22, 2010, 08:36:50 PM
Is this true?
I did not see any significant MPG improvement with electric fans. Better cooling ? yes.
rrob
Quote from: mauve66 on February 22, 2010, 07:22:22 PM
sacraficial anode
69 charger, 440, automatic
elacruze
Is this true?
Yeah, Pimp my truck is staffed with thermodynamic engineers...LOL
You may see some MPG improvement if you replace a large straight-drive fan with electrics, but little improvement over a clutch fan. Remember, it takes electricity to run those fans, and the alternator belt has to do the same amount of work to move the air as a fan belt would. If you want real MPG savings, get electric fans so that you can go to an electric water pump. The pump only turns at the most effective speed, which moves more water at idle than stock and doesn't overpump at high RPMs.
1968 505" EFI 4-speed
