8 3/4 leak
Started by charger72, July 31, 2005, 01:03:28 PM
charger72
I have a 8 3/4 rear that I cant seem to get to stop leaking. I have new axles seals and carrier gasket(pumpkin), but it still drips from the center section. How can I fix this?
73 Charger 440
Is it leaking from the front down? (Where the driveshaft meets...) If so Id say its the seal there (Im not sure about 8 3/4s though).
charger72
it leaks between the housing and the center section(pumpkin). right now I have 2 paper gaskets(Fel Pro) in it with silicone, but it is still dripping it out.
73 Charger 440
Im not sure then... Why 2 gaskets though?
charger72
since they are pretty thin, I figured 2 would help it out. I did check it before, and I couldnt find any cracks in the housing and it seemed like nothing was warped.
73 Charger 440
I would still use only 1 gasket though, and silicone both sides of it... then torque it how its supposed to be (order and such if there is any). The 2 gaskets mating with each other to me sounds like it would cause a leak (paper on paper).
THE HOUSING IS WELDED POSSIBLY  the welds are pourous [I hate caps lock ]
