Small block power
Started by Paul G, November 30, 2009, 10:11:29 PM
Paul G
How much power can be made from a small block, 360, run on pump gas and be streetable?
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
Foreman72
425ish...
even tho its for a 318 check out this article...
http://www.popularhotrodding.com/enginemasters/articles/mopar/0667em_mopar_318_engine/index.html
talks about small block stuff allot...all SBs are the same blocks just with different stroke/bores...(at least to my knowledge)
check out this book too
http://www.amazon.com/Small-Block-Mopar-Engines-Present-273-318-340-360/dp/0895864797
Eric "Foreman"
Previous: 1972 Dodge Charger
Current: 2002 Volvo S60
"The steps of a man are ordered by the LORD, and He delights in his way. Though he fall, he shall not be utterly cast down; For the LORD upholds him with His hand.
=Psalm 37:23-24=
"But store up for yourselves treasures in heaven..."
=Matthew 6:19-21=
:pat
 :Twocents:
The general idea for awesome big-block street motors pretty much applies to SB motors too:
Take the biggest commonly sold stock engine block, enlarge it with a cheap chinese cast stroker crank kit, stick decent aftermarket aluminum heads on it, and keep the size of the compression/cam/carb relatively small for the displacement.
Cooter
Ma Mopar does have that 440 Cu. In. Small Block out now............. :2thumbs:
