Fendertime, need some help!
Started by Belgium R/T -68, November 30, 2009, 11:44:34 AM
Belgium R/T -68
Getting time to put the fenders on but first I guess I should mount all the different kind of sealings I bought in the beginning of my
project because the catalog I ordered everything else from had these and said 68-70 B-body. When I tored my car apart I didn't find much of these things so I need some references. Checked FSM and Paul Heards book but can't find anything back from pictures.
So if anybody could help me with what I have here on my table and where it shold be placed I would be greatful, also if they should go on before
or after the fender goes on. ;)
Left top: Think I bought those ones from R/T spec with fasteners??
Right top: From Paddock, MO116A Innerfender seals
Left down: Paddock, FW6589 lower splash shield K-member
Middle down: Paddock, FSR02 Splash shield rubberkit
Right down: Paddock, CH2070 Splash guard seal
Per
bill440rt
Hi Per!
OK, this should be pretty easy.
Left top: Think I bought those ones from R/T spec with fasteners?? : These go just above the metal splash shields that mount behind the rear tire. They mount on the inside top at the rear of the fender.
Right top: From Paddock, MO116A Innerfender seals: Hard to tell since it's all rolled up, but I'd have to say at the front inside of the fender at the top.
Left down: Paddock, FW6589 lower splash shield K-member: These get pop-riveted to the bottoms of the frame rails just above where the strut rods are. There are lefts & rights.
Middle down: Paddock, FSR02 Splash shield rubberkit: These thin seals get clipped along the edge of the metal splash shields, and make contact with the insides of the fenders.
Right down: Paddock, CH2070 Splash guard seal: These get clipped to the inner fender aprons, there are access holes behind the wheels/front suspension on the inner fenders. The driver's side gets mounted on the outside (wheel side), the passenger side gets mounted on the inside (engine side).
Belgium R/T -68
Hi Bill :cheers:
About the first item, you mention rear tire - as in the rear wheeltire? If so where is the front of the fender?
Maybe I should learn the basics first, where is the front of the fender? I suppose at the grilleside?
Where are the fenderaprons located (what is it)?
Sorry for beeing kind of slow when it comes to the vocabulary of certain parts. :icon_smile_big:
Per
Belgium R/T -68
Checked the resto "database" here but couldn't find anything, some pics would be very useful.
Per
