wire tabs
Started by 1charger69, November 21, 2009, 11:53:14 AM
1charger69
where can i pick up some of those bend over tabs that hold the tail light wiring and mount to the trunk floor?
here is one guy selling those on ebay, found it a month ago or so, but pretty sure must be some on line dealer around
1charger69
Charger-Bodie
Call Mega Parts......608 452 2045 ask for Jamie.
1charger69
Thanks guys ...will do...anyone know how many i need?   and proper positioning? ;D
71_Charger_R/T
I just made my own. Use 1/2" banding strap, cut it to the length needed, radius the ends as originals, heat them with a torch till red hot (to soften and become more bendable) drill a hole to either screw on or plug weld (depending on the application). Bend them diagonally and dip in rubber dip used to coat tool handles. BADA BING you've got replacements for a fraction of the cost of the ones selling on ebay!
ORIGINAL
HOME MADE
STEPS.... RAW STOCK, BENT, DIPPED.
hemi-hampton
http://www.dodgecharger.com/forum/index.php/topic,33799.1140.html
there was some questions of those wire tabs in this thread. LEON.
bull
Charger-Bodie
Quote from: bull on December 12, 2009, 03:13:03 PM
Exactly like original for $5 each: http://www.megapartsusa.com/proddetail.asp?prod=146%2DVCB
And you dont even need to reinvent the wheel to use them.
Did you get yours welded on ? Curtis.
Silver R/T
Quote from: 71_Charger_R/T on December 11, 2009, 11:57:20 PM
best idea so far
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
71_Charger_R/T
Quote from: 1HotDaytona on December 12, 2009, 03:18:40 PM
I'd rather make a hundred of them for about $7.00 using a little ingenuity (A.K.A. reinventing the wheel) than spending $5.00 a piece for a simple little part that could add up to hundreds of dollars through out the car. Just trying to suggest an option for those of us who don't have money falling out of our cavities.  Thank you Silver R/T for your kind comment!
bull
Quote from: 71_Charger_R/T on December 12, 2009, 10:47:00 PM
Hundreds of dollars? How many are you planning on using?
Charger-Bodie
I guess my time is just as valueable to me.......I can work on someone else car in the time to fiddle around making things like that and still have less money invested than some people.
bill440rt
They weren't available back when I did my '70, I had to make my own the same way! I think I still have some extras floating around somewhere in my parts bin.
bull
There is one benefit to making your own that I can think of. The reprodcution tabs are bare metal with plastic coated tips so eventually rust will be an issue. However, if you made them and attached them to the valve cover before dipping them or heat shrinking them (whatever) they would be better protected. But if doing an exact reproduction is a priority to you you're not going to get any closer than the Megaparts tabs.
71_Charger_R/T
[/quote]
At $5.00 a pop. Between the trunk, floor pan and valve covers you can add up to at least $100.00 in a hurry, that's only 20. I've got 6 under my front seats alone.
1charger69
hows bout a quick list of where these lil buggers go around the car...and some ref pics to go along with ...thanks ;)
hemi-hampton
I've always just made my own because I never knew anybody made reproductions. If they do then they must have just started doing so only recently. :scratchchin: LEON.
bull
Quote from: hemi-hampton on December 14, 2009, 08:00:03 PM
What did you use to insulate the tips on your homemade jobbers?
hemi-hampton
