Deck Filler Plenum?
Started by MoparSam, October 29, 2009, 08:33:09 AM
MoparSam
I was inside the trunk of my '68 last night poking at rust and knocking out epoxy and filler (so I could get an idea on a sheet metal order for AMD) and I noticed the deck filler plenum is only attached at the base of the back glass channel and at the top of the trunk gutter, but not on the sides to the bottom of the deck filler panel.  Any one got an idea on why it is done this way and what in the wide world of sports is the plenum for?  Support? Thanks in advance!
'68 Charger R/T 440
'74 D-100 Adventurer 318
'75 Ramcharger 360 4x4 4 Speed
'78 Ramcharger 360 4x4 4 Speed
'67 Dart GT (Soon 440)
'05 Ram 1500 4.7
1/2 '71 Dart
Charger-Bodie
Its not welded to the deck filler , but it is (supposed to be) glued with a foam type caulk.
1charger69
is this the pc that the speakers set into?? behind the rear seat??
MoparSam
Quote from: 1HotDaytona on October 29, 2009, 09:24:53 AM
Ah, that makes sense with warping from welding, but they kinda went thin with the caulk cause there is only a 1/16" wide or less bead.
Quote from: 1charger69 on October 31, 2009, 03:56:14 PM
Almost but not quite, it attaches to the package tray and to the top trunk gutter, directly under the deck filler panel.  Any body know what the plenum is for?  Can it be taken out permanent?
'68 Charger R/T 440
'05 Ram 1500 4.7
1/2 '71 Dart
I think it is a stiffener and mount for rear defroster.......? Photos?  :scratchchin:
MoparSam
I don't have that good of lighting in the barn I work out of and the Chargers not moving right now but METROID has a good picture of one that shows its location.
'68 Charger R/T 440
'05 Ram 1500 4.7
1/2 '71 Dart
