What do you tink of SEM Rust-Mort?
Started by bull, October 24, 2009, 10:12:43 PM
bull
I bought a bottle of it to get in some tight spots with a sprayer but was curious if anyone has used it before I crack it open. I've always had very good luck with SEM stuff and figured this would probably be decent too but looking for some reviews.
Sublime/Sixpack
I've used it in the past with good results.  Can't comment as far as spraying it on, I've always used a brush to apply it.
mopar_nut_440_6
Rust Mort has been around for decades and is IMHO a very good product for what it was intended. I use to sell it under the permatex brand name, if I recall right. I am not certain but I thought the directions said to brush on. Not sure if it made a difference but that is what I recall.
I know, why did I post this? I am not sure why either. Not much help I know!
Cheers,
James
1968 Charger R/T 440
2004 Dodge Ram 2500 680 HP Cummins with attitude
bull
I was reading somewhere that some of these rust converter-type products can build up pretty thick, get hard and crack but this stuff is so thin I kind of doubt it would form a "shell" so to speak. Seems more like a thin primer.
Ooops, says here you have to top coat Rust Mort: http://semproducts.com/cms/Rust+&%3B+Corrosion+Protection/146.html Guess I won't be using it in those hard to reach places.
Silver R/T
it works just like por15, ive used it before, its good product. All it is conversion coating and most of them should be topcoated if exposed to UV rays.
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
