HP Exhaust manifolds
Started by Grip64, October 15, 2009, 03:46:03 PM
Grip64
Looking for some feedback here please fella's....
What times are you guy's getting at the strip running these manifolds ???
Check out F.A.S.T. racing stuff for the best times!  :yesnod:
Of course it depends on the build but some of the FAST guys are running low 10's through HP manifolds and exhaust. Make no mistake ; the manifolds are a cork and do limit horsepower. You need to be careful with cam selection....wide lobed profiles that reduce overlap and reversion seem to work much better with restrictive exhaust systems.
The difference with manifolds versus real headers is little or nothing when you're cruising around at 2000 rpm.
But once you pass 3500 the difference starts rearing its head more and more.  It might be a 30+ hp difference by the time you're up at 5500-6000 rpm.
Lifsgrt
I ran 13.049 @ 107mph with my 446 in Sept 2008 at Monster Mopar with stock HP manifolds and 3" TTI exhaust and Dynomax mufflers with 3:23 gears and a 727.  Picked up 2 mph and nearly .5 with the install of TTI headers.  :2thumbs:
Best time 11.07@121
mopar_nut_440_6
The stroker I have ran a 11.43 with HP manifolds through 3 inch exhaust. 4100 lb 69 with auto and 3800 stall with 3:23 gears. When changed to headers it picked up a half second in the 1/8.
477 with 509 DC cam, old school stroker build
1968 Charger R/T 440
2004 Dodge Ram 2500 680 HP Cummins with attitude
Grip64
Quote from: mopar_nut_440_6 on October 20, 2009, 08:19:18 PM
That's very impressive with those gears and all, i would like to here more about that build.... what heads were you using etc ??????
mopar_nut_440_6
I did not build the engine but bought it back with my 68.
Here is what I know:
11.8 : 1 Compression
Forged Flat top pistons from a motor home application
906 heads with decent porting and port matching, stainless valves, Titanium Locks
Crane Gold Roller Rockers
5/8 stroke Hemi Billet crank-Not sure of manufacturer but it is extremely high quality
Stock rods beam polished, shot peened
Balanced, blueprinted
Holley Street Dominator Intake
MSD Pro Billet distributor
had a 950 Holley DP
